BC coilover installation questions
03-21-2014, 02:38 AM | #1 |
105
Rep 2,692
I'm fitting my coilovers tomorrow. How do i work out what length the drop links should be?
Also on the rear do i use the oem lower spring perch? I know the top one isn't re-used but not sure about the lower one. Lastly fitting of the rear shock at the top. Is the info below in the pic correct? Thanks |
03-21-2014, 04:05 AM | #3 |
Rep 172
Out of interest does the BC kit come with a new upper spring perch?
I would say the washers look good, does the shock comes with a new nut or can you reuse the existing? |
03-21-2014, 04:16 AM | #4 |
105
Rep 2,692
Hey Dan
Yes it comes with a new upper perch and they specifically say to use that and not the OEM one but they dont mention the lower one. The shock comes with a new nut and washer spacer washer in that order but i dont think you can re-use the OEM nut |
03-21-2014, 04:18 AM | #5 |
105
Rep 2,692
Just realised bottom left of that pic you can just about see the upper spring perch and then there is the rubber washer on the floor that goes between the perch and the chassis
03-21-2014, 06:30 AM | #6 |
Rep 172
Yes, makes sense as it is height adjustable.
The OE nut is captive to the washer so not easily removable. I think you have it worked out correctly. At least this is the way I would interpret the kit. I just fitted the B12 kit and the instructions were less than helpful but some simple common sense saw it installed correctly. |
03-21-2014, 02:55 PM | #7 |
10
Rep 102
Did you sort the drop links? Presuming they are adjustable and the shell case length is the same as OE and that the drop link bracket on the damper is the same as OE, adjust the droplink to OE length.
If the shell case is adjusted shorter, you may need to increase the length of the drop link a little. If made longer than OE, you may need to reduce the drop link's length a little. |
03-21-2014, 03:40 PM | #8 | |
105
Rep 2,692
Basically adjust the drop link accordingly to maintain the overall setting of the anti roll bar? Eg if the bracket for the drop link on the coilover is 5cm lower then adjust drop link and make it 5cm longer? That sort of logic? |
