Trouble Codes
03-18-2014, 05:01 AM | #1 |
Rep 154
Trouble Codes
Hi all,
I just got a handheld code reader to add to my growing toolbox and hooked it up to see how healthy my E90 is and it threw up two codes. A0B2 and A0B5. I haven't reset anything yet and there is no warning light on the dash but the car is running a little bit rough at the moment. The car is a 2006 320i auto with 65k on the clock. Any help appreciated. Gaz |
03-18-2014, 05:12 AM | #2 |
888
Rep 9,097
A0B2:
Fault CAS supply Error will not cause a warning light Error is not currently present Test conditions have been completed A0B5: Signal identification peed error Error will not cause a warning light Error is currently present Test conditions have been completed Timeout I would clear them and see if they return to start with. They appears to be linked with CAS and it should not interfere with the engine running status / condition.
03-18-2014, 05:38 AM | #4 | |
888
Rep 9,097
It is the one which identify the key and provide algorithm to the engine of the car to start.
03-18-2014, 07:35 AM | #5 |
Rep 154
Thanks for the help Makkan00
Sounds like an expensive fix if it goes Pete-Tong. I had my radiator develop a hole on me on the M25 the other week and I need the Vacuum pump doing and CCV by the looks of things. This could be the makings of an expensive month, hopefully the CAS dont cause me any issues. Thanks once again. Gaz |
