Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Please answer my stupid question
      03-15-2014, 05:51 PM   #1
CivicKilla
Drives: 09 E92 x-drive
I have a 09 e92xi and I want to know if the factory wheels from a 01 e39 m5 will fit without a lot of hassle (a direct bolt on).
Thanks for the help
      03-15-2014, 09:15 PM   #2
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
690
Drives: 2010 335d, 2014 328d
Thanks for the help
No.
      03-16-2014, 08:08 AM   #3
michael1972
15
Drives: 2007 335i coupe
+1. Offsets are probably to low might poke out a lot and you would need hub centric rings to go from the 74.1mm hub sz to 72.6mm. Tirerack sells the rings. Theyer pretty inexspensive. I bought some to try and run my varrstoen wheels I bought for my e39 on my e46 m3. I did not like how much the fronts poked out though. If you dont mind the poke then the hc rings are all you need to make them fit.
