Need help with replacement sizing: Weird DTC issues
03-14-2014, 07:31 PM | #1 |
160
Rep 275
I am in the dreaded position of needing to replace my summer tires on my 2011 335xi sedan. I am hoping the community can help with some questions.
I plan to replace the run flats with normal tires in an effort to save some money. I currently have 255/30/19 on the rear and 225/35/19 on the front. The wheels aren't factory (BMW optional wheels). I am currently running my winter tires on the factory wheels (18" BMW M appearance pkg). 245/40/18 on the rear and 225/40/18 on the front. The door sticker lists recommended tires as 225/40/18 on the front and 255/35/18 on the rear. Okay, all that said, here is my problem. I bought the car used and this is my second winter with the winter tires. I had zero issues with the tires last winter. However, I started to experience the DTC kicking in on dry pavement when making even normal turns. The cruise control also pulsates and kicks off when going over minor bumps on the hwy. I did not have either of these issues last winter with the winter tires on the car. The dealer took a look and said it was because I had the wrong size tires on the car and should have what it says on the door sticker. I didn't buy it, but what could I do so I've been living with the quirkiness all winter. My fear is that I am going to start having similar issues with the new summer tires that I buy. I never had any issues in the past with the summer tires, but that didn't seem to matter with the winter tires. Further, I feel like I will be on my own if the problems arise because the dealer will blame the wrong size tires. Of course I want to run my 19" wheels for the summer regardless. I am wondering if anyone can offer some insight or has experienced similar issues? Also, Tire Rack lists different sizes for my optional 19" tires. 235/35/19 for the front and 265/30/19 for the rear. Should I go with the sizes TR recommends? Or, should I go with what "I know works" and the same size I am replacing, fearing that the quirkiness may manifest itself no matter what I choose? I hope this all makes sense and I really appreciate any help someone can offer. I will answer any questions for clarification. Thanks in advance! |
03-14-2014, 07:39 PM | #2 | |
223
Rep 5,120
03-14-2014, 09:23 PM | #3 |
160
Rep 275
Thanks for the info! This is my second winter on the tires and there was at least one before I bought the car. Now I am freaking that the xdrive is compromised. UGH. If you don't mind, would you clarify what you mean by the front and rear being within 1%?
03-14-2014, 09:58 PM | #4 |
Life is better with burnouts
97
Rep 611
Drives: BMW
The front and rear rolling diameters have to be one percent within each others range. The rolling diameter is the diameter of the tires.
03-15-2014, 10:30 AM | #5 | |
223
Rep 5,120
With 235/35/19 and 265/30/19 it is 0.857% difference, which is fine. 235/35/19 and 275/30/19 is 0.077%. |
