tire plug kit
03-14-2014, 07:25 AM | #1 |
14
Rep 208
tire plug kit
hi im moving away from RFT to normal tires. I wanted to keep some sort of plug kit in the trunk in case for long trips. i hear the slime ones can damage your TPMS. are their any kits that would be a good temporary fix to drive to a service station?
thanks.
2008 E90 328 X-drive -KW V1- Auto-Sport-Blacklines-LED interior lighting
Summer: Style 195 F-225/40/18 R-255/35/18 on Bridgestone RE760 Sport Winter: Style 161 - Sottozero RFT 225/45/17 square |
03-14-2014, 10:15 AM | #2 |
Guest
Rep n/a
Drives:
I've had good luck with each of these kits and they have worked on more than a few tires FOR THE LIFE OF THE TIRE as a permanent solution:
http://www.amazon.com/Stop-Go-Tubele...=tire+plug+kit http://www.amazon.com/Safety-Seal-St...ds=safety+seal The Stop-Go solution is definitely much more user friendly, but it all comes down to what you ran over to begin with and how it's sticking out of the tire. If it's a straight shot into the "meat" of the tread, it should work fine, but if there is a screw or nail jammed into the tread sideways, you'd want a gooey strip in there instead. Search Amazon for a decent pump while you're at it as well and use something like this to avoid blowing the fuse @ the cigarette lighter port: http://www.amazon.com/Roadpro-Batter...ighter+adapter |
03-14-2014, 10:49 AM | #3 |
31
Rep 722
Drives: 2008 BMW 335xi
I was gonna do a plug kit, but after my recent blow out on the side wall, it would've served no purpose. Ordered a real spare tire instead.
03-15-2014, 03:19 PM | #4 |
57
Rep 224
I used a 16oz can of fix-a-flat that's tpms safe on a fast leak and it worked like a charm. I had the tire replaced a week later and tpms was fine. I monitored tire pressure during the week and it didn't seem to leak at all. Just be careful using it. The stuff did spray everywhere when I stopped pushing down the button. Look away or wear protective eyewear.
I also have a spare, plug kit, and tire compressor in the trunk just in case, but the fix-a-flat/compressor was the easiest fix for my situation. |
03-15-2014, 05:01 PM | #5 |
14
Rep 208
what is the safest way? anyone where to get the bmw mobility kit?
FCobra....i think i might try the first kit...
03-17-2014, 11:33 PM | #6 |
533
Rep 2,872
I also, intend to move away from the RFT's.
But hit the same problem, assuming I run over a nail, i'm fine (as I can be) with my plugs, and inflator. But, what about sidewall damage? Call a tow? I have free-roadside with my warranty, but I'd assume some people on here have spares. Who makes a proper size "Donut" if you will, for these cars?
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
