stat_begrl_rechts_short_circuit_counter = 60 - 00 3C . <
03-04-2014, 03:30 PM | #1 |
Rep 24
Hey guys, I have a 2009 e90 lci, my right hand side angel eye is no longer coming on after i attempted to change the oem bulb to the clear, not sure if something shorted out but i put the oem bulb back and it still refuses to come on, left hand side works fine.
I tried resetting the short circuit counter using tool32 but when I read the status_lampen_kurzschluss_counter, in the results window all are = 0 except, stat_begrl_rechts_short_circuit_counter = 60 - 00 3C . < I then tried clearing using steurn_reset_kurzschlussabschaltung with "data" box check results read error_lamp_nr If I uncheck "data" it says error selected light Tried using reset_kurzschluss_sperre with checked "data" i get error_lamp_nr If I uncheck "data" it says OKAY but angel eye still won't come on. When I read status_lampen_kurzschluss_counter, it still has'nt changed I do not know german so this is quite challenging to undersand, i would think that the above error is with regard to the right angel eye, does anyone know how to clear/reset this or know what it is? Thanks |
03-05-2014, 03:24 AM | #3 |
Rep 24
06-13-2014, 01:09 PM | #6 |
93
Rep 713
Steven, do you know why I can't reset short circuit on BEGRL_RECHTS
apiJobData("FRM_70","status_lampen_kurzschluss_cou nter",{DATA}, 2,"stat_begrl_rechts_short_circuit_counter") {DATA}: 2 Bytes 0000 : 00 03 .. Satz : 0 OBJECT = frm_70 SAETZE = 1 JOBNAME = status_lampen_kurzschluss_counter VARIANTE = FRM_70 JOBSTATUS = UBATTCURRENT = -1 UBATTHISTORY = -1 IGNITIONCURRENT = -1 IGNITIONHISTORY = -1 Satz : 1 JOB_STATUS = OKAY STAT_BEGRL_RECHTS_SHORT_CIRCUIT_COUNTER = 14 00 0E .. When I put 0x05 I get this: apiJobData("FRM_70","steuern_reset_kurzschlussabsc haltung",{DATA}, 2,"") {DATA}: 2 Bytes 0000 : 00 05 .. Satz : 0 OBJECT = frm_70 SAETZE = 1 JOBNAME = steuern_reset_kurzschlussabschaltung VARIANTE = FRM_70 JOBSTATUS = UBATTCURRENT = -1 UBATTHISTORY = -1 IGNITIONCURRENT = -1 IGNITIONHISTORY = -1 Satz : 1 JOB_STATUS = ERROR_LAMP_NR _TEL_ANTWORT = 64 Bytes 0000 : BC F1 72 5A 80 00 00 09 24 05 30 07 32 0E 60 56 ¼ñrZ?... $.0.2.`V 0010 : 45 20 11 01 12 09 00 13 09 0D 14 01 04 14 00 00 E ...... ........ 0020 : 00 00 00 00 09 20 62 44 00 05 53 05 30 30 39 32 ..... bD ..S.0092 0030 : 45 47 30 30 30 39 32 45 47 30 46 31 39 30 41 9B EG00092E G0F190A? |
06-15-2014, 09:17 PM | #9 | |
442
Rep 18,331
06-10-2015, 01:11 AM | #11 |
681
Rep 3,696
06-10-2015, 09:54 PM | #12 |
681
Rep 3,696
Yeay, i got my AE's working... not gonna give any more update other then that
just kidding. Okay here is what i did: 1) Make sure i'm on map 0 2) Load INPA and make sure i have both black dots so i know my cable works 3) Close INPA (very important to do this) 4) launch TOOL32.EXE 5) click on "jobs" and start typing out: steuern_reset_kurzshlussabschaltung 6) click on the text box located under arguements and enter the various hex values (you will need to try both check marked and unchecked for the box that says DATA). Press F5 or double click on the job name to send each command one by one a) arguement = 0x0 (received error result) b) 0x1 (received error result) c) 0x2 (received error result) d) 0x3 (received error result) e) 0x4 (received error result) f) 0x5 (received error result) g) 0x6 (received error result) h) 0x7 (received error result) i) 0x8 (received error result) j) 0x9 (received error result) k) 0xa (received error result) l) 0xb (Got my first OKAY, and started to jump up and down with joy) 7) went back to the job for reading the counter and instead of showing 50... it was now 1 8) closed TOOL32.EXE and open INPA 9) cleared all errors in the FRM 10) start my car and enjoyed seeing my driver side AE alive again |
