F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Windshield washer fluid...
GetBMWParts
      02-08-2014, 08:37 AM   #1
Alamat
17
Drives: 2014 435xi Sport Line
Alert now up, needs washer fluid. I was thinking of getting the RainX kind but some guys said it would "trip" the monitor. Can I just use the supermarket blue kind?
Originally Posted by MikeRR View Post
When you spend that much on a car it is stupid to talk about needs - nobody "needs" a 4 Series.
      02-08-2014, 10:12 AM   #2
34.50
34.50's Avatar
38
Drives: 2013 335i xDrive Sport Line
Yes, you can use the "supermarket blue" kind. I had gallons of RainX, and the car would alert my it'd be low on windshield washer fluid, even after I refilled the reservoir. It was annoying to see that message even though I knew I had windshield washer fluid. The "supermarket blue" kind doesn't exhibit this behavior.
There's a thread on here with people complaining about the same issue with RainX.
2013 BMW 335i xDrive Sport Line
      02-08-2014, 10:29 AM   #3
Alamat
17
Thanks man! Appreciate it!
      02-19-2014, 02:21 PM   #4
BMWOOF
Drives: 2014 335i Xdrive ///MSport
I have the same problem and I did not know until now that the RainX version is not good.
First time I had the dealer change the entire tank.
This time is the second time happening. I have just filled with Rain X solution(before I read this post).
Do you think the warning sign will go away once I drain the fluid and replace with the regular blue cheap ones @34.50 ?
      02-19-2014, 03:37 PM   #5
n55x3
72
Drives: n55 BMWs
Wow, that's all I buy is the Orange Rain X stuff and we've never once seen the low level alert trigger in any of our BMWs. Good to know moving forward though. Is it the orange stuff you are talking about or are there different kinds of Rain X washer fluids? The Orange stuff has a really low temp rating.
      02-19-2014, 05:45 PM   #6
BMWOOF
This is what I have put in.
In my case, the low washer warning came on, then I filled with this and now it does not go off.
      02-19-2014, 07:02 PM   #7
Professor///M
Professor///M's Avatar
No_Country
819
Drives: 2022 M3, 2022 X5 40i;
I don't use rain x anymore because it stained my AW car years ago
      02-19-2014, 09:11 PM   #8
34.50
34.50's Avatar
38
Yep, my advice is to give the blue windshield washer fluids a shot. You have nothing to lose. Good luck!
      02-20-2014, 03:46 PM   #9
BMWOOF
Thanks guys. Will try.
      02-20-2014, 04:42 PM   #10
Damn Dirty Ape
33
Drives: 2015 Infiniti Q50S
except the benefits rain-x provides.
      02-21-2014, 01:10 PM   #11
Medal
Medal's Avatar
480
Drives: 2021 M3C
Yep!
I was about to post a warning....my 2013 335i Xdrive just blew the washer sensor because I used that stuff...wtf!?
Oh well...blue fluid it is :/
      02-21-2014, 01:42 PM   #12
BMWOOF
I just drained the entire rain x washer fluid and put the regular cheap blue stuff in the car.
Yep, still telling me washer fluid is low. Heading to the dealership. Grrrr
      04-13-2014, 11:50 AM   #13
gregh
Drives: 2014 328i xDrive sedan
My first washer fluid fill up after purchase, I used RainX Heavy Duty -25. Not long after, the low washer fluid warning would come on shortly after every start up. I filled the reservoir to the brim to no avail.
Service department assured me that when the RainX is gone and I switch to the regular blue stuff, the warning would go away. Being a bit impatient, I ran the sprayers until the reservoir was empty. I did this three more times with plain water to flush out the RainX, and then I filled it to the top with the regular blue stuff. The low washer fluid warning still comes on shortly after every start up.
Does it take time for the system to reset or recalibrate before it will shut off? Or does the sensor just need to be replaced?
      04-13-2014, 01:35 PM   #14
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
It shouldn't have to recalibrate. I had the same issue with Rain X setting off my sensor this past winter as well. Eventually I topped off the washer fluid tank with some blue washer fluid and the warning never came back. You shouldn't have to empty out the reservoir as when I added the blue fluid my reservoir wasn't empty, so even a mixture of Rain X and blue fluid seemed to be enough to clear the warning light.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      04-13-2014, 02:11 PM   #15
gregh
As I said, I already did that and it did not work. My only conclusion at this point is that the sensor is malfunctioning.
      04-25-2014, 07:17 PM   #16
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
9720
Drives: M Sport 335i
2014 335i  [9.74]
I stopped by my dealer's (Park Ave BMW) service location to buy some OEM washer concentrate, and the Parts guy was questioning why I was even buying it since they will refill the fluid for free. I bought it anyway since I didn't want to have to visit Service just to add windshield washer fluid. I think the concentrate cost $4.
      08-18-2014, 08:02 PM   #17
gregh
To follow up, I brought the car back to the dealer and they attempted to clean the sensor. It still wouldn't work, so they did a warranty replacement.
Lesson learned -- stick with the cheapo blue stuff.
The only part that bugs me is that they don't just own up to the problem. It's costing them, after all.
      08-18-2014, 10:54 PM   #18
sirdrebin
Drives: MY2013 335xi sedan ordered
You can still get the Rain-X benefits while keeping the cheapo-but-safe "Blue Stuff" in your reservoir for on-the-move use only...that's what I do.
Rain-X glass cleaner, which has the same benefits, comes in a pump spray (12-14 oz.??) bottle available at most auto parts stores which I regularly use every 7-10 days to clean all the car windows b-4 I drive off for the day. If I (rarely) need window cleaning while driving I just use the "Blue" in the reservoir and spritz/wiper clean as I drive. (FYI: on the interior side of all the glass I use "Invisible Glass".)
      08-26-2014, 11:21 AM   #19
RedlinePSI
127
Drives: Something else
Do you have to literally schedule a regular service to have them top off your tank? My warning light is on too and I want to just go there and have them do it but I'm not waiting an hour for this.
      02-05-2018, 01:39 PM   #20
M Smurf
M Smurf's Avatar
157
Drives: 2013 328i M Sport
Originally Posted by Medal View Post
Yep!
The Rain-X orange was recently recommended to me. Found a CLASS ACTION LAWSUIT filed in jersey 2 years ago about the destruction to the sensors found in most german cars.
FYI
      02-05-2018, 02:05 PM   #21
M2Rush
83
Drives: 2014 BSM 335i x-drive
Just get the BMW one, it's not expensive and they can't blame aftermarket for clog jets, otherwise use the cheap blue stuff, mind you in Canada BMW actually sells purple ones(goes up to -45 celsius) instead of blue.
      02-09-2018, 06:34 PM   #22
Class5Kayaker
Class5Kayaker's Avatar
52
Drives: 2016 BMW F15, 2014 Porsche 991
The BMW concentrate is like $4. Heard too many horror stories to try and save a buck (literally.....$1). Dilute the concentrate according to your local temps (instructions are on the bottle). I use an old gallon container that used to contain RainX to mix my BMW concentrate with water. Unless you're in an area that is sub-zero temps, one bottle of BMW concentrate mixed with water fills the gallon jug at the correct ratio.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic
2014 Porsche 991- Sapphire Blue Metallic
f30post
