02-05-2014, 09:46 AM | #1 |
13
Rep 74
First oil change
I know this topic has came up many time but I read somewhere that an oil change was done at factory after the engine is tested. Is this true? If not would you do a oil change before or after it hits 1000 miles?
02-05-2014, 10:17 AM | #2 |
294
Rep 2,602
No idea about engine testing and oil changes, but would seem to make sense to remove any machining leftovers and like just in a gearbox, no doubt there is a magnet in the sump to catch "filings". Many advocate an oil change at ~1,000 miles (BMW do if it's an M vehicle), but it's not on the schedule to do for any other BMW vehicle. Your choice at the end of the day! It won't do any harm, other than the cost of a filter, oil and time to do it.
02-05-2014, 10:35 AM | #4 |
6659
Rep 15,858
This is a possibility. There are some good articles written by the oil developers, who show how oil changes its characteristics over its life and changing early is not all positive.
Some new engine oil fills are with specially formulated bed-in oils, so not recommended for an early change. One of my VW diesels had a bed-in oil, saw the VW data sheet which clearly stated not to drain early, as it could have warranty implications. VW wanted 10,000 miles on the original oil. Don't know what BMW do these days, but there is no change requirement as the M-cars. HighlandPete |
02-05-2014, 10:42 AM | #6 |
10998
Rep 32,881
Just forget about any servicing or oil changes until the service warning comes up in the dash! That's what it's designed for!
02-05-2014, 02:25 PM | #7 |
167
Rep 1,919
02-05-2014, 02:57 PM | #8 | |
1983
Rep 3,216
Remember when BMW had (still have) issues with timing chains breaking on various (especially diesel) engines ? A lot of independents seriously believe that part of the cause is these extended service intervals. Quite simply, the oil is absolutely worn out by the time it has done 18,000 miles. Or put it another way. Even with BMW, an oil and oil filter change is £200 (roughly). Done in the middle of your service computer gap, that's an extra £1000 in the first 100,000 miles. How much is an engine ? |
02-05-2014, 03:43 PM | #9 | |
10998
Rep 32,881
However if the car is remapped or has a tuning box then it is probably best to change oil a bit more often as the specified intervals are calculated based on the standars engine. |
02-06-2014, 03:47 AM | #10 | |
13
Rep 74
