My first autocross class win
01-26-2014, 09:07 AM | #1 |
37
Rep 386
I did an autocross with the local S2000 club yesterday. It was their annual winter event where we run the course in opposite directions in the morning and afternoon. Your fastest runs in each direction are added together to give you your final placing.
This club is my favorite and usually has the highest attendance and the stiffest competition locally other than SCCA. Crazy thing is, by their class rules, my car gets a 1.5 times displacement multiplier due to forced induction. So my 3.0 liter is considered a 4.5 liter A couple days ago I encountered a P30FF code/limp mode running anything other than the stock (stage 0) map. It's still unresolved, so I went ahead and ran yesterday's event on the stock map. Also on stock suspension and wheels with Hankook R-S3s (225/40/18, 255/35/18). I managed my first ever class win and placed 11th overall out of 67 drivers. Further proof for me that many of the common "must have" mods you read about on the forums simply aren't necessary to be successful. Here's my best two runs plus a few silly slides
'07 E92 BMW 335i
01-26-2014, 02:29 PM | #2 |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
Congratulations! Impressive. No easy feet besting S2ks! 225s up front even.
I agree with your last paragraph!
01-26-2014, 11:42 PM | #3 |
42
Rep 659
Driver mod is the most important lol. Congrats! But what do you use to measure the g's? I've always wanted one. And I've read on road-n-track that stock 335 only do 0.85g at the skid, I wanna test that claim myself.
01-27-2014, 07:04 AM | #4 | |
37
Rep 386
I'm using an AiM SOLO GPS to measure the G forces. I've pretty much figured out that my car is on the limit of my control at around 1.1 Gs on the R-S3s. Sometimes it'll register higher, but that's usually because the corner has favorable banking.
'07 E92 BMW 335i
02-05-2014, 03:38 PM | #6 |
31
Rep 595
Very nice, man!!! Congrats on the win. Just curious, do they follow the similar class structure as SCCA? What class does your car fall into with this group?
02-17-2014, 09:03 AM | #7 | |
37
Rep 386
- Rotary engine multiplies displacement by 2.0. -Usage of forced induction multiplies displacement by 1.5. (This is in addition to the rotary multiplier, if applicable.) Tires with a wear rating under 140 must use the R class. - Class 1/1R is for engines under 2.3 liters, except Honda S2000 and Lotus Elise/Exige. - Class 2/2R is for engines over 2.2 liters, but under 4.0 liters, plus Honda S2000. - Class 3/3R is for engines over 3.9 liters, plus Lotus Elise/Exige. - Class S2000 is only for Honda S2000 (usage of tires with a wear rating under 140 reverts to Class 2R). As a side note, I figured out my P30ff code. The vacuum line running from my diverter valves to the throttle body had come off completely at the TB. No wonder the car wasn't even making 8 psi
'07 E92 BMW 335i
02-23-2014, 04:44 PM | #8 |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
I was there - acj was killing it
He made everybody else in 3 look bad Lesson here is - learn 2 drive. Failing that, buy parts |
02-23-2014, 05:53 PM | #9 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Square would only add more oversteer
02-25-2014, 12:30 PM | #10 |
37
Rep 386
Right on. You ready for CoTA? I just installed some new R-S3s. I got a little over 10k miles of daily driving and some goofing around, 4 track days, and probably 50+ autocross runs on my outgoing set which isn't too bad. Also ordered a new fmic. Can't wait!
'07 E92 BMW 335i
02-25-2014, 01:46 PM | #11 | |
162
Rep 573
Have camber plates on order with ground-control - waiting for those to show up. When I get them and install, that'll dictate how much rubber I can put on the new wheels Also waiting on availability from coolcarbon for brake pads - they say any day now lots of balls in the air my two runs at that event - on my fail-bag 225 UTQG 500 LRR Run-flat all season's I'll have to go back and create a highlight reel that included the spins
02-26-2014, 01:51 AM | #12 | |
Rep 50
