EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      01-14-2014, 08:42 PM   #1
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Question New 275/35 19 Michelin PSS for the F8X?
When I decided to switch to 275/35R19 tires on my E92, I did some in depth research to understand the differences between a 265/35 and a 275/35 regarding contact patch dimensions and tire weight tradeoff. I came to the conclusion that the 275 offered 20% more rubber on the road vs the 265 mostly due to smaller grooves in the thread.
http://www.m3post.com/forums/showthread.php?t=848092
Based on the picture from the Detroit release, it seems that the 275/35 on the F8X has the wider grooves of the 265 tire (also as on the 235/35, 245/35 and 255/35). See picture below of the 275/35 on my E92 vs the 275/35 on the F80.
      01-14-2014, 08:49 PM   #2
solstice
5457
Drives: 2015 M3 6MT
Try measuring each groove and contact stripe, add the combined of each and calculate the ratio of groove vs patch.
      01-14-2014, 08:52 PM   #3
CanAutM3
General
CanAutM3's Avatar
21117
Have a look at the thread I reference to in my OP.
      01-14-2014, 09:01 PM   #4
LDSM
LDSM's Avatar
344
Drives: ...
Reading the sidewalls the tires on the show cars are 255/35 19
      01-14-2014, 09:03 PM   #5
CanAutM3
General
CanAutM3's Avatar
21117
255/35 in front, but 275/35 in the rear. The picture I posted is from the rear tires.
      01-14-2014, 09:06 PM   #6
Jockey
Jockey's Avatar
3448
Drives: 992 C4S
I think it may be part of an optical illusion between a tire with full tread and a tire near it's wear bars
      01-14-2014, 09:07 PM   #7
LDSM
LDSM's Avatar
344
Drives: ...
Ah my mistake, I was looking at the fronts
      01-14-2014, 09:12 PM   #8
CanAutM3
General
CanAutM3's Avatar
21117
I don't believe it is. When I got my new 275, the sea/land ratio looked very much like the picture of my worn set and not like the ones on the F80.
      01-14-2014, 09:14 PM   #9
Jockey
Jockey's Avatar
3448
Drives: 992 C4S
I'm sure tirerack could answer your question then.
Trying to judge this from differing distances with different wear patterns is only going to lead to guesses.
      01-14-2014, 09:23 PM   #10
Needsdecaf
Needsdecaf's Avatar
6586
Drives: 2024 G80 Comp xDrive
That's ok, we need it down here in TX to deal with all the water!
      01-14-2014, 09:48 PM   #11
solstice
5457
Drives: 2015 M3 6MT
Same here, I got the 265s and they are awesome in the wet which we have enough of here in Seattle...
I'm actually putting on a new set of rears on this Friday after 24k miles on the first set. Superb tires.
      01-14-2014, 09:54 PM   #12
GregW / Oregon
Commander-In-Chief
2119
Contact patch
When I decided to switch to 275/35R19 tires on my E92, I did some in depth research to understand the differences between a 265/35 and a 275/35 regarding contact patch dimensions and tire weight tradeoff. I came to the conclusion that the 275 offered 20% more contact path width vs the 265 mostly due to smaller grooves in the thread.
Regardless of contact patch width, the area will be the same.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      01-15-2014, 08:44 AM   #13
CanAutM3
General
CanAutM3's Avatar
21117
I see where you are coming from and agree. I have debated this myslef manytimes: for a given inflation pressure, increasing the width of a tire changes the contact patch shape but does not linearly change the contact patch size.
However here we are not discussing contact patch size. The contact patch is the the area where the tire deforms to contact the road. The pressure inside the tire times the contact patch area equals the load the tire is carrying (minus the load the sidewall is carrying). This area remains relatively constant regardless of the thread pattern of the tire; this because the air pushes on the inside of the tire and not on the individual thread blocks. So a slick tire will have the same contact patch size (tire deformation) than a wet tire with big grooves (assuming same inflation pressure and sidewall stiffness). However, since the slick tire does not have any grooves, it has much more rubber in contact with the road and therefore more grip.
Comparing the two 275/35 PSS tires above, both will have essentially the same contact patch area, but the one with the smaller grooves will have more rubber in contact with the road, hence more grip.
      01-15-2014, 01:42 PM   #14
bavarian19
General
bavarian19's Avatar
517
Drives: Car
More rubber in contact with the road does not mean more grip. It means the total distribution of weight is over a larger surface area, so less downward pressure per square inch.
Measuring grip is much more complex than that.
      01-15-2014, 02:42 PM   #15
CanAutM3
General
CanAutM3's Avatar
21117
Yes, I know, the physics of tire grip are very complex. But more rubber in contact with the road does mean more grip.
A tire gripping the road is more than just normal force times the friction coefficient as you imply. There are two major components to tire grip: standard friction and rubber element interlocking with the pavement irregularities. The later is directly related to how much rubber is contact with the road. Otherwise, why would race cars use slicks?
      01-15-2014, 03:59 PM   #16
aajami
aajami's Avatar
432
Drives: Space Gray '09 E92 M3
This is the part where I hijack the thread and complain that Michelin has yet to develop a 285/30-19 application of the PSS.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      01-16-2014, 02:09 AM   #17
swamp2
swamp2's Avatar
611
Drives: E92 M3
Let's not forget correcting the very common misconception that a wider tire has the same contact area as a narrower tire at the same inflation pressure. This is certainly a bit OT to the OP but was being discussed. This "fact" works for things like spherical balloons, not tires with heavy steel belts, stiff side walls and stiff solid rubber tread blocks.
This myth is very clearly refuted here.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
f80post
