BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > petrol additives for injector cleaning.
      12-27-2013, 11:00 AM   #1
John320d
John320d's Avatar
31
Drives: BMW 320d E93
Trying to help my grandaughter with her high mileage misfiring mini. I wondered if anyone has actually cured a misfire by using an injector cleaning additive such as redex or wynns etc. My thoughts are to start at the cheap end of the cures. Anyone?.
      12-27-2013, 11:12 AM   #2
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
Try getting any fault codes read it may be something as simple as a plug or coil pack
      12-27-2013, 11:20 AM   #3
John320d
John320d's Avatar
31
I suspect having fault codes read might be more costly than a bottle of Wynns.
      12-27-2013, 11:35 AM   #4
SO8
243
Drives: BMW G42 M240i xdrive
Try BG44K ... I have used it twice in the wife's car and it certainly stopped it running rough the 1st time I used at about 40,000 miles ... it working after about 30 miles ... thus using a second tin a year later !
It is supposed to be far stronger than 'normal' injector cleaners and has more of the expensive additives that clean than the cheaper 'Halfords' types of cleaner.
If you Google reviews on BG44 you won't find anything negative (well I didn't anyway).
I don't think many of the reputable makes on the market are bad - just that this is far stronger but still safe. You pay for the strength though - it is getting on for £20 a tin (which is enough for one tank of petrol in one go).
I would certainly recommend it on the basis of the change in my wife's car !
      12-27-2013, 11:57 AM   #5
nik patel
nik patel's Avatar
31
Drives: BMW 330d M Sport Pro G20
BG44KK looks interesting...... anyone else have experience with this?
Nik
      12-27-2013, 11:59 AM   #6
scooba0010
scooba0010's Avatar
156
Drives: F32 430D-MOTORSPORT
Hi John,
Is your GD a member off the AA or Rac , Just tell them it won't start and when the guy arrives she says I have got it to start but it runs shit , He will scan it for a young lady .
My son had issues with his 330I petrol bmw . They scanned his and found it was a coil pack
      12-27-2013, 12:25 PM   #7
makkan00
makkan00's Avatar
886
Drives: F83 and F36
I don't think many of the reputable makes on the market are bad - just that this is far stronger but still safe. You pay for the strength though - it is getting on for 20 a tin (which is enough for one tank of petrol in one go).
+1
Best so far!
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      12-27-2013, 12:34 PM   #8
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
+1
Using injector cleaner when you're not even sure of the cause of the misfire could be a complete waste of time (and money). As well as plugs and coils, it might also be caused by carbon build-up on the backs of the inlet valves, which I understand is a common problem with direct injection Mini engines.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      12-27-2013, 12:47 PM   #9
nik patel
nik patel's Avatar
31
That's ckeeky John! lol
Nik
      12-27-2013, 01:49 PM   #10
nik patel
nik patel's Avatar
31
Interesting Redex review on Fifth Gear!
Nik
      12-28-2013, 09:13 AM   #11
SO8
243
That test is for octane boosters not specifically cleaners.
      12-28-2013, 09:37 AM   #12
nik patel
nik patel's Avatar
31
Think its for the standard red petrol one, not octane.
Nik
