2011 BMW 335i: Idrive controller replacement?
12-20-2013, 11:01 AM | #1 |
36
Rep 201
I just bought a 2011 335i and the Idrive controller is pretty worn out, "clicky" and "loose" especially compared to the controller on my 2013 F10. I assume this is not normal operation.
Although a replacement is only $225 it appears that it isn't a simple swap, and some DEALER coding is required for some reason, correct? *search only found threads about 2007-2008 idrive replacements*
2023 G05 X5 x40i Phytonic Blue
....many prior BMW's back to a 1966 1600 |
12-20-2013, 11:43 AM | #2 |
Rep 48
The installation of the part is very easy, but yes, coding is necessary. It doesn’t have to be done at a dealer. I know for a fact the Auto Logic can code it. If done with ISTA-P, it will most likely require an update of all vehicle’s SW. I have seen quite of a few E9x’s take over 9 hrs to program recently, so if you go that route, prepare in advance to leave it over night. As always with programming, any number of things can go wrong while programming. Don’t compare an E car to an F car, lots changed with Boardnet 2020. Even if the items look similar in appearance, operation has most likely changed due to bus changes.
12-20-2013, 11:50 AM | #3 | |
829
Rep 3,387
12-20-2013, 12:18 PM | #4 | |
36
Rep 201
I might just call a dealer and see what they have to say (besides that it takes 5 days and $10,000)
12-20-2013, 12:25 PM | #5 | |
Rep 48
whats77inaname, my bad I should not have said "necessary." Seems nothing should be an absolute these days. Last edited by DouggyB; 12-20-2013 at 03:59 PM.. |
12-20-2013, 12:48 PM | #6 | |
36
Rep 201
Jason from Tischer (GetBMWparts) replied that it's a direct swap no dealer needed for a late model 2011.
....many prior BMW's back to a 1966 1600 Last edited by Keyser Soze; 12-20-2013 at 02:34 PM.. |
12-20-2013, 03:01 PM | #7 |
Rep 48
If the supplier says it will work then awesome! If you install it and it's not working, try coding it before returning it
