M3 control arms
12-16-2013, 05:03 PM | #1 |
Rep 80
M3 control arms
I have been reading up about fitting m3 control arms and subframe bushes for my e92 330D
Every post I read is from the USA Has anyone from the UK done this and can give me some info? What the kit people are using is ect. A lot of people talking about TSW Who are they and what's the difference between TSW and OEM?? |
12-16-2013, 10:07 PM | #2 | |
400
Rep 5,623
http://www.e90post.com/forums/showthread.php?t=843644 |
12-17-2013, 01:40 AM | #3 | |
Rep 80
Now need to see if anyone has done it in the uk Cheers Brett. |
12-17-2013, 02:18 AM | #4 | |
400
Rep 5,623
If you read the linked thread, a member called phil has installed them, but just the fronts. |
12-17-2013, 03:15 AM | #6 |
118
Rep 2,216
Drives: E91 330d M Sport
Out of interest, what alignment settings did your garage use? Reading through Phil's thread, it seems the M3 geometry didn't suit his car at all.
Just how many Yorkshire sheep can you fit inside one exhaust?
12-17-2013, 04:23 AM | #7 |
112
Rep 2,621
The m3 toe was slightly too aggressive. The car was pulling hard on road camber and even strong winds! The rear end also felt loose.. Ok now though.
Annoyingly one of the rear arms got flagged on the MOT as having excessive play.... Should have just done them all and been done with it! Alignments are expensive!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
12-17-2013, 04:37 AM | #8 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
I was going to go this route... but i think i am just going to buy some powerflex bushes, have them fitted and call it a day... no alignment needed after
12-17-2013, 04:59 AM | #9 | |
76
Rep 1,518
I think a better choice would be to replace with tension and control arm bushes with poly ones and then get the camber pins pulled and increase the camber up front. Would require the alignment but would you'd get the other advantage of m3 lower arms too. |
12-17-2013, 05:19 AM | #10 |
46
Rep 891
12-17-2013, 07:27 AM | #11 |
170
Rep 3,828
Why? Nothing is being adjusted? just old bushes popped out and new ones inserted.
I'm happy with the stock handling too... So doubt i would even consider increasing the camber... I know the extra wear on the tyres in minimal as long as it is all set up correctly... |
12-17-2013, 07:53 AM | #12 | |
46
Rep 891
suspension geometry is minute changes, literally segments of a degree (minutes). removing something and replacing it is going to require you to recheck all the settings. regardless if you want M3 geometry or OE. |
02-27-2014, 06:32 AM | #14 | |
130
Rep 935
03-01-2014, 01:36 AM | #15 |
Rep 80
Bump
Can someone confirm that I need: Front: JTC1423 JTC1424 JTC1426 JTC1427 Rear: JTC1428 JTC1429 JTC1430 JTC1431 And a levelling rod which I have no idea where to get it from? Any ideas? Cheers Brett. |
03-01-2014, 02:26 AM | #16 |
112
Rep 2,621
Get the levelling rod from bmminiparts. Only required if you have xenons.
I have a set of the rear arms (brand new in boxes) if you are about to order these. £180 shipped.
03-01-2014, 09:00 AM | #18 | |
112
Rep 2,621
I've got part numbers: JTC1428 JTC1429 JTC1430 JTC1431 I'd let them go for £180 shipped - ie £25 cheaper than anywhere else..
03-01-2014, 11:03 AM | #20 |
112
Rep 2,621
Afraid not.
I'm already losing £25 plus postage £12 on them.
03-01-2014, 12:26 PM | #22 |
112
Rep 2,621
They are brand new in boxes.
You are welcome to buy at full price from elsewhere. My price isn't unreasonable. Let me know if you want them.
