Anybody running spacers on msport 17's
12-16-2013, 10:30 AM | #1 |
Wheelbarrow Edition
60
Rep 1,608
12-19-2013, 01:47 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
I usually run 18s but currently have 17s on with winter tyres. I've kept the same spacers, namely 15mm front and rear. You'll be fine with the same set-up.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
12-19-2013, 02:36 AM | #4 |
30
Rep 572
How are you finding the ride quality with the H&Rs?
I'll be lowering mine soon, still contemplating between H&R and Eibachs but I would say I'm 90% set on the H&Rs at the moment... |
12-19-2013, 03:46 AM | #5 | |
616
Rep 3,194
Personal opinion, if ride quality is important to you, avoid H&R springs like the plague! They give one of the hardest rides of any aftermarket springs. Obviously I'd recommend the Ohlins set up, but I appreciate that may be outside your budget. How about Eibach springs paired with KONI FSD dampers?
12-19-2013, 03:53 AM | #7 |
30
Rep 572
My question was to OP Phil
I wish I could afford Ohlins I really like the drop on H&Rs after seeing a few other members with similar cars on similar setup (H&R with oem MSports) and at the moment it's feasible budget wise as well. Reason I'm not leaning towards Eibachs are because of the minimal drop that other members have mentioned on MSports, so I am willing to compromise a little on the ride quality. |
12-19-2013, 03:56 AM | #8 |
684
Rep 4,261
I think 17's will always look a bit lost in these arches. Even 18's look small in the front arch. Spacers should help a bit. I have 25mm on the rear of mine.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
12-19-2013, 04:32 AM | #9 |
Wheelbarrow Edition
60
Rep 1,608
I don't want them to rub at all mind you?
The quality on the h&r's imo is pretty awesome. Obviously i haven't tried the eibachs but imo the ride is around 90% as comfortable as oem. It is in no way jarring or a harsh ride. I am rather impressed. Obviously i have had cars in the past with kw coilovers etc so to me the ride is more than comfortable. My other half has eibach sportlines on her mkV golf and my h&r's are nowhere near as harsh as hers. I would honestly say if you didnt know it was lowered as a passenger i doubt you'd even be able to tell the ride was anything but stock And im running the 17's as A) i like them B) the tyre's are reasonable. Well as reasonable as runflats can be C) the ride is good |
12-19-2013, 04:35 AM | #10 |
616
Rep 3,194
12-19-2013, 04:48 AM | #11 | |
112
Rep 609
To be honest I'm quite happy with the ride height on the rear axle (M Sport), its just the front that could do with coming down a little. From what I've read Eibach does this (closes the arch), just not an aggressive drop. |
12-19-2013, 06:00 AM | #13 | |
105
Rep 2,692
12-19-2013, 07:10 AM | #14 |
684
Rep 4,261
12-19-2013, 07:16 AM | #15 | |
30
Rep 572
http://www.e90post.com/forums/showthread.php?t=926225 |
12-19-2013, 03:48 PM | #16 |
Wheelbarrow Edition
60
Rep 1,608
Wasn't sure
So ordered one set at 15mm for the time being. Will try them both on the back and front and see what i think. Then i can judge if i need 20's for the back. Or run 12's up front Will give me a rough idea |
