12-11-2013, 08:05 AM | #1 | |
177
Rep 464
Official M3 M4 engine specs vs Bimmerpost specs
What does that meen for the previously in this forum leaked/rumored bore-stroke numbers/ratio ??? No oversquare engine as thought and an normal BMW undersquare N55 block instead ??? Greetings from an confused BMW M3 CRT |
12-11-2013, 08:09 AM | #2 |
General
21115
Rep 20,741
Drives: 2021 911 turbo
550 N-m, that is 406 ft-lb. More than anticipated...
I am also curious to find out about the official bore and stroke figures. |
12-11-2013, 08:29 AM | #3 |
Rep 116
8.3l/km is 28.34mpg
431ps is 425hp 1497kg is 3300lbs (all fluids, 90% fuel, no driver) 1572kg is 3466lbs (plus 68kg driver and 7kg luggage) Last edited by Kadema; 12-11-2013 at 08:56 AM.. |
12-11-2013, 10:37 AM | #4 |
General
21115
Rep 20,741
The Autocar articles specifies identical bore and stroke as the N55...
12-11-2013, 01:44 PM | #5 |
Moderator
7509
Rep 19,370
Even now, there are two threads with different displacements listed as official. One is 3027 cm3 based on the 89.6x80 cm bore and stroke numbers, and the other is 2979 cm3 (as shown above in this thread as well) which of course matches the N55 and implies the same 84x89.6 cm bore and stroke as that engine.
I have to assume Jason has his numbers correct though... |
12-11-2013, 01:52 PM | #7 |
353
Rep 1,749
this is very important because it defines which class the car competes in. which one is it?
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
12-11-2013, 02:54 PM | #9 |
M3AT LOVER
322
Rep 1,853
12-11-2013, 02:58 PM | #10 | |
177
Rep 464
Sorry this means for me to 100% N55 derivate or better B58 derivate ... I am nearly sure that we would see this engine in an detuned and less refined version in the next 5er series or allready in the coming 7er series 3.027ccm and 89,6mm x 80mm could also be the specs of the rumored V6 based in the S63Tu !? Last edited by BMW M3 CRT; 12-11-2013 at 03:14 PM.. |
