Something is not right at the back [Help please] Maybe fixed!
12-10-2013, 01:11 AM | #1 |
684
Rep 4,261
Ok a little bit of background info.
For a few weeks I have has what I thought was a balance issue on the NSR bit of wobble through the seat 70 and above , was getting new tyres anyway so lived with it for a couple of weeks. Got the new tyres fitted [ Dunlop SP Maxx ] and the issue is still there. Also , when accelerating hard it feels as if that side of the car is [ its hard to explain ] feel's like the whole corner of the car is loose, car seams to squat down and looses traction very easily throwing the car sideways as if struggling for grip. Need to get this sorted so any suggestions where to start would be great. Cheers and a Merry Christmas to you.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
12-10-2013, 04:26 AM | #3 |
32
Rep 1,271
Drives: 335i (sadly gone)
I had a similar issue when I changed tyres. It felt like the car was weaving ant the steering wheel was being pulled about. Not sure if that is the same but it was the tracking and alignment severley out.
12-10-2013, 04:43 AM | #4 | |
684
Rep 4,261
This is quite severe Nick, if I pull out of a junction turning right, it feels as if the back end on the passenger side is squatting right down.
12-10-2013, 05:14 AM | #6 |
684
Rep 4,261
Sounds plausible mate. Got some new springs on the way.
12-10-2013, 05:18 AM | #7 |
67
Rep 1,273
Sounds suspension related, give it a good bounce and see how it compares to the other side. I’d say knackered shock. Also worth considering alignment. Hit any big potholes recently?!
12-10-2013, 05:26 AM | #8 |
684
Rep 4,261
Not that I can recall Greg, maybe it's just wear, car has done 80k now.
12-10-2013, 11:13 AM | #9 |
42
Rep 825
More than likley a goosed shocker but if these are anything like E46's - the springs are notorious for snapping too, although not sure a snapped spring would present quite as severe issues as a knackered shock
12-10-2013, 01:07 PM | #10 |
Gibbon
26
Rep 192
I had a similar issue on my E46 Coupe, it had all sorts of suspension problems and tramlined like nothing I'd ever driven before, but the problem like you describe ended up being a seized brake caliper believe it or not.
Although admittedly in your case I would think it's probably a snapped spring. Good luck with it! |
12-10-2013, 04:44 PM | #11 | ||
684
Rep 4,261
12-13-2013, 08:04 AM | #12 |
684
Rep 4,261
So I bought some Apex springs off of G-10 on here.
They needed a bit of a makeover and Apex yellow is not in my plans. So i thought, we modify everything else, why not these Clean Acid etch primer First coat Top coat and done
12-13-2013, 12:29 PM | #13 |
Rep 303
HI Sparky
Part numbers for bumpstops/ secondary dampers M3 front 31332225377 and z4 rear 33536770350.
blackchrome csl,s // eibach pro kit //bitstein B4s// shortened bumpstops//front and rear brembo performance brakes// jbl ms8//focal 100krs// rainbow dlx5 centre, rear//jenhert xe200//cas audio corner loaded sub// jl10v3 sub// jl xd500/3 xd400/4// technic harness// 808mguy adapters |
12-13-2013, 12:30 PM | #14 |
684
Rep 4,261
Cheers macck you are a star.
12-14-2013, 11:34 AM | #15 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
Trailing arm bushes
12-16-2013, 02:22 AM | #16 |
23
Rep 157
Hi Sparky,
Interested in the outcome of this as I am sure I have the same issue myself. Been to two indy's, both had a look and prodded around but said all seemed fine. However it still did not feel right to me, I started thinking I was being to picky and imagining things that were not there until I read your post. Cheers, Eddie
2008 E92 325i Black Sapphire M-Sport Coupe
12-16-2013, 02:48 PM | #18 |
684
Rep 4,261
Mechanic has had the car today, no play anywhere! Annoying, damper maybe? Would that cause the "wheel out of balance" effect?
12-16-2013, 04:37 PM | #20 |
684
Rep 4,261
Don't know, possible but not sure that would account for the other effects.
12-17-2013, 06:32 AM | #21 |
949
Rep 29,345
Drives: 997.2 GT3
Just ignore me.
12-17-2013, 08:12 AM | #22 |
684
Rep 4,261
LOL I wasn't, he checked and found know play at all.
