Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Question: How to Disable MOST bus?
      12-04-2013, 02:09 AM   #1
Isetta
Isetta's Avatar
Greece
Drives: E90
Hi,
This is my first post here, and I want to thank all of you helpfull guys for the useful info.
My car is a E90 manufactured on April 2008 (EU specs) without MOST bus.
I swapped my Business Head Unit (fitted from factory) for a used Professional one with a fiber optic connector at the back.
Sound quality is improved but now I'm not able to receive any software updates from BMW dealer, probably because the MOST ring is broken. Aux is also lost.
I need to disable MOST, but I read somewhere that I will need to put the Pro HU in a car with MOST in order to disable it or I need different equipment than a K+DCAN USB Cable and NCS-Expert.
I have been able to communicate with the RAD module via INPA (trying some tests) and I have also been able to change vehicle order adding option $663
I can’t read the 2RAD ecu getting this
ERROR in CABD!
COAPI-2041: wrong ecu coding index
A_E65R: CODIERINDEX = 20h
I use a K+DCAN USB Cable, NCS-Expertentool V.3.1.0 and SP DATEN 50.2
QUESTION: How can I read the 2RAD module and disable MOST?
Can anyone help?
Thanks
Edit: Head Unit Manufacturing Date is newer than car's
      08-04-2014, 01:40 PM   #2
prbaxter
Drives: bmw
bump - i'd like to know the answer to this too.
      08-04-2014, 01:59 PM   #3
cryptomit
93
Drives: 320d 2012
Install Standard Tools 2.12 and it will resolve your issue.
      08-05-2014, 03:03 AM   #4
Sensible_
529
Drives: 2008 E90
Try CODERIUNGINDEX_LESSEN after you select ECU and before you SG_CODIEREN.
This has worked for me before.
      08-18-2014, 01:44 PM   #5
Red_Bean_Bun
62
Drives: E92
Add emoa to the VO and code car ....
Tags
disable most
