How long do your tyres last?
12-03-2013, 03:26 PM | #1 |
12
Rep 123
I replaced the rears on my 335d 18 months ago, standard Bridgestone run flat 19's. in 13k miles, one is at 3mm and the other below 2mm! Does that sound right? I'm only a hoon 20% of the time.
12-03-2013, 03:54 PM | #3 |
344
Rep 6,176
Depends on how often you drive and your style of driving really I suppose. I have a set for winters and a summer set up so can't really say much but 18 months sounds about a good time to change given tread.
12-03-2013, 04:20 PM | #4 |
15
Rep 791
depends on the tyre compound aswell. Bridgstomes, perelli and alk the other high end makes I dont rate for grip or wear tbh. Parada spec2 or other mid range tyres grip better in wet and dry and dont seem to scrub down.
I have nangkang ns2's on my car. People wouod assume they are crao because of price........but out of re050a potenzas, p zero rosso and bridgestone contact3's. They are the only tyre than can put my 400+bhp on the floor. Iv done 6k so far and they are still at 6.5mm all round. |
12-03-2013, 04:52 PM | #6 | |
112
Rep 4,021
I thought they were very poor and the reviews and figures in official tests often back that up. |
12-03-2013, 06:11 PM | #9 |
Dieseasal
204
Rep 6,881
I managed 9k miles out of my last set of contis.
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
12-03-2013, 06:38 PM | #11 |
15
Rep 791
My ns2's are the only tyre iv found that can hold my power and actually lasy. An ns2 was specifically made for track enthusiasts...........apparently (use that very loosely)
Its like yokahoma tyres. Known as shit. Yet a parada soec 2 will out shine most tyres on the market, same a a toyo t1r. I dont do over priced ditch finder. Till I got my p zero nero off the front of my car. I was under the imoression 335i's had terrible understeer. |
12-03-2013, 06:43 PM | #12 |
Rep 138
Similar to Apl320d above... I've done almost 22k and I've got about 4mm on the rears and 5mm on the fronts. Hoping to get near to 30k out of them.
I'm aware this doesn't accurately reflect the wear seen on a 335d though. |
12-03-2013, 08:26 PM | #13 |
15
Rep 791
A 320d barely spins with tc of in the wet. I had one as a courtesy car when my car had some recal work done and it was gutless. I would hope a 320d would get good milesge.
12-04-2013, 12:47 AM | #14 |
27
Rep 214
335d. My last set of rears lasted 10k and were completely bold. Goodyear Asymmetric 2.
Fronts still look brand new. Have now switched to Falken 453 on the rears to see how they perform. |
12-04-2013, 02:07 AM | #15 |
684
Rep 4,261
Rears about 3 months , fronts 6-8 months.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
12-04-2013, 03:20 AM | #17 |
12
Rep 123
thanks guys, don't feel too bad now - looks like i'm driving the car properly atleast
Those with 335's getting 20k plus from the rears, jeez - stamp on the go faster pedal now and then!! |
12-04-2013, 03:31 AM | #18 |
Rep 138
12-04-2013, 03:35 AM | #19 |
Dieseasal
204
Rep 6,881
Sigh? Why? He's right! It's a fairly slow car so tyres will last longer as they are under less friction most of the time.
12-04-2013, 03:54 AM | #20 |
Wheelbarrow Edition
60
Rep 1,608
Its not slow
My work van is slow, 65bhp n/a 1.9 diesel The 320d is no supercar but around 8s to 60 its certainly not gutless. Obviously tyres will last longer, its mostly down to how you drive it. I can burn a set of fronts in my work van in 8k! Mainly because its lit round the bends to make up for lack of grunt on the straights! |
12-04-2013, 04:21 AM | #21 | |
112
Rep 4,021
I bought my car at 27k and the rears were still original. They still had tread left too, but were heavily worn on the inner edge. 20k is easily achievable for a normal driver. A bit of blasting and the daily commute. To be into just a few thousand miles, your either doing donuts or more than likely needlessly spinning up the inside wheel being heavy footed. Both of which are a bit pointless. Last edited by Kerr; 12-04-2013 at 04:57 AM.. |
12-04-2013, 04:45 AM | #22 |
118
Rep 2,216
Drives: E91 330d M Sport
On my 330d:
Kumho KU39 (rear) 12k to the wear bars. Falken FK452 (rear) 10k to the wear bars. Goodyear F1 Assy 2 (rear) 12k and still on 3-4mm, so probably 15k when I change them next year,
Just how many Yorkshire sheep can you fit inside one exhaust?
