BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      10-26-2007, 07:50 PM   #1
Coyot
Drives: N/A
EDC dampers: Expendable or serviceable?
They must cost a lot, so here is a practical question.
Can they be serviced / repaired or do they have to be thrown away (changed) at the end of their term, like ordinary dampers?
What's the firm's policy on that?
Btw: how much would they cost as spare parts?
      10-27-2007, 12:23 PM   #2
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
24967
Drives: '22 Chalk Gray Porsche C2S
That's a good question; one that probably cannot be answered accurately at this time being that the car and its EDC suspension is new. It would be nice if BMW made them rebuildable like an aftermarket damper.
      11-23-2007, 06:29 PM   #3
vm
Drives: 2018 Alfa Romeo Giulia
But is history is any indication the EDC system on the e34 M5 had very expensive and not rebuildable shocks. I expect that these M3 shocks will be very expensive to replace. They might be very durable though, so this just might not be an important issue. Aftermarket solutions might also be possible.
      11-23-2007, 08:07 PM   #4
swamp2
swamp2's Avatar
609
Drives: E92 M3
Rebuild?
Most shocks are serviceable/rebuildable whether or not the factory/manufacturer claims that or not. Unless the shocks are quite expensive it will probably be less expensive to replace them rather than rebuild them. I'm not sure what your current shop rate is but mine is $90/hr. Rebuilding shocks is likely to be a skill most regular shops don't have. Fine work, getting very small parts crystal clean. Dealing with easy to damage and difficult to install seals, special tools, etc. Last but not least my OEM E36 M3 shocks lasted well over 100k miles. I would not feel too bad about replacing shocks on that type of schedule.
      11-24-2007, 01:40 PM   #5
guardodoc
guardodoc's Avatar
34
Drives: M3 e92, 1986 325e 2021 X5 40i
$574.74
Real OEM lists Rear Shock Absorber for M5 with EDC as $574.74 EDC control sensor is $525.64. Accelerating sensors price is not listed.
Perhaps this would give you an idea of the price for parts on the M3 with EDC shocks. Unsure how hard it is to tell if it's a bad shock or a bad sensor or accelerating sensor.
      11-24-2007, 05:01 PM   #6
swamp2
swamp2's Avatar
609
Drives: E92 M3
Shock or Shocks, aren't they only sold in pairs?
      11-24-2007, 08:35 PM   #7
guardodoc
guardodoc's Avatar
34
shocks
The price listed is for 2 shocks and a single control
01 SHOCK ABSORBER, REAR 2 33522283127 $574.74
02 HEX BOLT M14X105 ZNS 2 33506758105 $3.79
03 SPRING PAD LOWER 2 33532229913 $9.04
04 ADDITIONAL SHOCK ABSORBER, REAR 2 33532282524 $18.97
05 SUPPORTING CUP 2 33526758283
06 SPRING PAD UPPER 2 33532282767 $11.38
07 GUIDE SUPPORT 2 33522282766 $66.96 +core
08 SELF-LOCKING COLLAR NUT M8-8-ZNS 6 12/2006 31331092887 $0.56
08 SELF-LOCKING COLLAR NUT M8-8-ZNS3 6 07119904295 $0.30
09 PLATE 2 33521095030 $0.57
10 SELF-LOCKING HEX NUT M12X1,5 05 2 32211095267 $0.36
11 TUBING GUIDE 2 33526758888
12 EDC-K CONTROL UNIT 1 09/2005 37156767281 ENDED
12 EDC-K CONTROL UNIT 1 03/2007 37146773912 $525.64
13 BRACKET 1 37107835872 $32.09
14 CLIP 1 37146752824 $0.32
15 PLASTIC NUT M6 1 16131176747 $0.48
16 ACCELERATING SENSOR 2 04/2006 37146770204 $141.73
FRONT WHEEL ARCH
16 ACCELERATING SENSOR 2 37146776212
FRONT WHEEL ARCH
17 FILLISTER-HEAD SCREW M6X10 4 07119919962 $0.17
18 ACCELERATING SENSOR 1 05/2006 37146770205 $141.73
REAR WHEEL ARCH
18 ACCELERATING SENSOR 1 05/2006 37146776213
REAR WHEEL ARCH
19 HEX NUT 2 07119904030
20 UNIVERSAL SOCKET HOUSING UNCODED 3 POL. 1 61138365348 $1.95
ONLY IN CONJUNCTION WITH
-- BUSHING CONTACT 0,2- 0,5MM ? 61130005199 $1.28
-- BUSHING CONTACT 0,75MM ? 61130006665 $1.12
22 UNIVERSAL SOCKET HOUSING UNCODED 18 POL. 1 61138364666 $0.39
-- BUSHING CONTACT 0,2- 0,5MM ? 61130005197 $1.28
-- COVERING CAP 18 POL. ? 61138364662 $2.01
23 SOCKET HOUSING 10 POL./WEISS 1 61131383522 $5.30
-- RUNDSTECKH 1,0-2,5MM ? 61131376204 $0.76
-- RUNDSTECKH 2,5-4,0MM ? 61131376206 $0.84
For comparison: a 2007 550i
FOR VEHICLES WITH
M SPORTS SUSPENSION
S704A=YES
01 SHOCK ABSORBER, REAR 33527905315 $198.65
Search this Thread:
Advanced Search
m3post
