M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      11-24-2013, 09:33 AM   #1
skypx
Veteran U.S. Army
skypx's Avatar
Germany
60
Drives: ///M
Safely removing ENET cable
Is there a safe way to remove it? Seems to be stuck.
      11-24-2013, 05:01 PM   #2
skypx
Veteran U.S. Army
skypx's Avatar
Germany
60
Drives: ///M
Turns out this is a known issue. New cables are a pita to remove.
      11-26-2013, 09:48 PM   #3
avlnch
127
Drives: 2013 Individual M5
My cable I use to code goes in and out without trouble.
The cable for my P3 gauge is so difficult to remove. It pisses me off to no end.
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
      05-09-2014, 01:20 PM   #4
pillpusher84
pillpusher84's Avatar
55
Drives: 2014 550xi M-Sport Silver
(My cables DON'T GET STUCK!!)
FYI ... anyone looking to buy an ENET Cable, can purchase from me. I personally make these cables and sell for $20 each shipped within the USA (international shipping extra) via eBay.
I can also help you code your car remotely via TeamViewer remote software at no charge & point you to where you can obtain the software needed to download for no charge as well.
      05-09-2014, 01:56 PM   #5
nybimmerfan
nybimmerfan's Avatar
38
Drives: 6-Spd Manual MCB M5
I do not have problems inserting and getting out my ENET (car connector to Ethernet) cable. A friend of mine bought a similar cable from an ebay supplier and he has problem getting it off that he just left the cable connected at the car connector end. I got mine from a supplier in Eastern Europe which was quite pricey and do see several supplier in ebay at reasonable prices.
      10-24-2014, 03:33 AM   #6
falsalem
falsalem's Avatar
Kuwait
14
Drives: 2013 F10 M5 Alpine White
I'm on your eBay page. Is the following description for the 2013 f10 M5 cable :
OBD2 ENET Ethernet Cable for BMW F-Series Coding ESYS OBDII OBD-II RJ45 RJ-45
      10-24-2014, 09:19 AM   #7
v3n0m
57
Drives: 2013 MCB M5
I had a problem getting mine out. After I got it out (had to pull REALLY hard) I cut out a notch where it's raised and haven't had a problem since.
      02-22-2017, 06:47 AM   #8
joemulder
13
Drives: bmw 535xi
I am in the same situation..
could you please share a picture where to cut?
thanks!!
I am new here. Thank you for your help!!!
      02-22-2017, 09:00 AM   #9
v3n0m
57
Drives: 2013 MCB M5
thanks!!
I posted a photo here.
http://f10.m5post.com/forums/showthread.php?t=810739
      02-22-2017, 09:59 AM   #10
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
New cables are snug. Just pull straight down as to not damage the pins, it will come out. You can notch it like mentioned above but is not necessary once you've used it a bit.
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
m5post
