E91 (pre-LCI) Offsets - will these fit?
11-21-2013, 04:30 AM | #1 |
Rep 11
Hi,
I'm sure this type of thing has been asked many a time... but here it goes: I want to change the wheels on my e91 Msport (330d) (Pre-LCI) - I want the wheels to have a lower offset than the current MV3's - I much prefer a flusher look than these wheels currently offer and would like to change the style too rather than simply spacing. i have found a set of wheels with the following spec F 18x8" ET20 R 18x9" ET24 will these fit with sensible tyres? not really a fan of the stretched look... I'd prefer not to roll arches but i have done in the past on a 350z (18x10's all round!) any help on this would be greatly appreciated. |
11-21-2013, 04:38 AM | #2 |
72
Rep 1,646
with them being 8s and 9s i dont see it being a problem at all mate,
im running 8.5/9.5 with ET 22 and they sit perfect!
Instagram @p5uml
11-21-2013, 05:19 AM | #4 |
72
Rep 1,646
i had my arches rolled anyways mate just in case and its not expensive to do so - so definitely worth while getting done IMO
Instagram @p5uml
11-21-2013, 06:13 AM | #5 |
Rep 11
yeah, think i paid around 80 to get the rears done on my 350 so not too bad..
Also, noticed that you have a coupe, is there any difference between the coupe and the wagon in terms of space available? |
11-21-2013, 06:46 AM | #6 |
72
Rep 1,646
as far as i am aware there shouldnt be mate, they are aggressive offsets but again they are only 8s and 9s...will an arch role IMO you would be fine!
Instagram @p5uml
11-21-2013, 09:02 AM | #7 |
46
Rep 891
according to the offset guides on the wheels and tyres section of the forum, ET30 is the minimum you can go to without an "aggressive" fitment (read: wheels that dont fit properly)
ET30 with a 255 tyre on a 9" rim will be perfect. ET24 you may need to dick about with to get them to fit also, there are fitment differences between E90, E91 and E92, as well as pre and post LCI. i believe pre-LCI E91's have the most "generous" arches, but the above spec is still the recommended minimum offset. |
11-21-2013, 10:56 AM | #8 |
28
Rep 459
As for rears, I run a 9.5 et18 on the rear of my e91, with rolled arches and some camber. Tyres are 255, so a little stretch, but all ok. Previously ran with ET15, 9.5j with a 255 tyre. Mine is a Pre-LCI and is on coilovers.
What suspensions will you be running?
E91 330i M Sport : Coilovers : Simota Air Intake : BMW Performance Brakes : 335 Style Exhaust : BMW Performance Colour Coded Engine Bay : BMW Strut Brace : 19" 1M Style Rims
My Journal Thread : CLICK HERE |
11-21-2013, 11:16 AM | #9 |
103
Rep 1,184
you should be fine... im running 8.5 et28, 9.5 et25... 225 and 255 which is a tiny bit stretched but im very low as well....
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
11-21-2013, 11:21 AM | #10 |
103
Rep 1,184
oh and im running stock camber and haven't rolled my arches
11-21-2013, 05:18 PM | #11 |
Rep 11
Hmm ok, so seems like wouldn't/shouldn't be too much issue then - now I just have to decide whether to go for this particular set... Decisions decisions...
Suspension wise, it's just standard msport at the moment and will probably only go as far as springs due to the roads I travel on everyday not being ideal! |
