Do Many people run meth in the uk?
11-18-2013, 09:04 AM | #1 |
43
Rep 397
Just curious to know whether many people run meth here In the uk as it seems big over in the states?
What sort of price it is for the install? And general pro's/ con's of using it? Thanks |
11-18-2013, 09:09 AM | #2 |
Rep 180
Drives: BMW E90 M3 ZCP
Not a Brit but european. Contact the best WMI vendor Aquamist. Located in the UK. I installed their HFS-4 a few months ago. Great kit, but on the pricey end. Richard provides the best support (phone, email and forum) I have ever experienced.
11-18-2013, 10:00 AM | #3 |
112
Rep 2,621
There are a few of us running meth.
Pro's: More power/Torque, Cleaning of valves (important in a DI engine), Chemical intercooling (more reliable power), Cheap to buy the kit, Meth is cheap. Cons: Meth is flammable (respect needed), if you don't have a failsafe and go too aggressive things go bad quickly. Overall if you do your research and err on the side of caution then its a great system. I use the JB4 paired with the BMS meth kit - works great and is the best price/performance/safety compromise. The HFS-4 is the best kit money can buy. For install - DIY. Should you have a problem in future (leaks, air in lines etc) you'll be much better placed on fault finding than having to pay someone to solve simple issues that will come up.. Otherwise there is a Devils Own distributor in the UK who can do installs - worth checking him out anyway to buy pieces of the kit in the UK rather than shipping it all in..
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
11-18-2013, 01:04 PM | #4 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
Thanks for chiming in Phil
Ben, i previously asked Phil all about meth and he is very knowledgable. A few other questions worth asking. Obviously a lot of us would be running JB4 G5... and so the obvious choice would be the BMW Meth kit with FSB as it has all kinds of fail safes and works well with the JB4. BUT if we were to fork out a bit more and run an aquamist kit... is it as straight forward as using the JB4 Meth kit? Phil are you still running a Windshield Washer kit? or have you moved to a Boot kit? Also what ChargePipe (CP) is best to use? Should we retain the stock Diverter Valves (DV) or Use aftermarket ones? Is it dangerous to use BOVs as they vent to atmosphere? Should we use two nipples in the CP to get better atomisation or consider fabbing a way of injection just after the exit of the intercooler? AM I MISSING ANYTHING? |
11-18-2013, 01:11 PM | #5 |
Rep 180
I first ran a ER charge pipe with dual bungs. Later fitted two bungs on IC cold side, better atomization and even spread between the cylinders. Currently run 0,5+0,7mm jets on stock turbos and 70% meth.
11-18-2013, 02:05 PM | #6 |
112
Rep 2,621
The aquamist kit has its own failsafes, I wouldn't pair it with a jb4.
You can use a hybrid kit with the Bms failsafe - buy the pump, tank etc in the UK and just the fsb from the USA. I'm still using the WW tank, it's not something I'm going to recommend to others. I run 50:50 mix for (relative) safety, I'm still planning on getting a trunk tank but have had no problems with the ww kit - hence it's been low on the priority list..
11-18-2013, 02:15 PM | #7 | ||
170
Rep 3,828
Thank you for your input. In order to run 2 bungs on the cold side of the intercooler. Was it fairly close to the exit of the intercooler? Have you got any pics of the bungs yo used and how it is all fitted? I was always more interested in this method of installation. Maybe one bung close to intercooler and one in the CP? I take it you are running a trunk setup? Quote:
I still love the idea of a WW kit for ease of install and removal |
11-18-2013, 02:56 PM | #8 |
684
Rep 4,261
A lot of the guys in the States run BOV's with Meth. I will be also when my points come off my license
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
11-19-2013, 04:46 AM | #9 | |
Rep 180
Aquamist gauge hidden in the compartment in front of the shifter and "databox" in the glovebox. HFS-4 can be integrated with JB4 but you might aswell buy a cheaper kit then. I would however get Aquamist compression fittings as they are second to none. Edit: added pic of where I routed the fuel line out the trunk. Same place the exhaust flap vacuum line goes. First tried the hole in the front of the same compartment but I did not like the hard bend behind the left rear wheel arch. Last edited by johmei; 11-19-2013 at 04:53 AM.. |
11-19-2013, 09:47 AM | #10 |
112
Rep 2,621
Great work. That's exactly where I want my tank to go..
Do you have more photos?
11-19-2013, 10:10 AM | #11 |
Rep 180
Thanks, it was a fun project. I really never took any pictures once it was installed, I should have. I have a few of routing wires inside the car but it's like any other trunk-dash wiring. I have one of the pump and tank setup before it went in the car (se attached). The aquamist pump has inlet/outlet the wrong way and should not be mounted on this tank as I had in previous pics. Some mount it "upside down, but not a good idea as it will not be gravity fed like my setup. If I had an amp I would put the pump under the floor in the center of the trunk and make a hole for the tube down there.
E90 M3 ZCP 2010
E92 335i 2007 black edition |
11-19-2013, 10:17 AM | #12 |
112
Rep 2,621
Mine doesn't have an amp either.
I was going to put the pump under the floor but this approach is clean. How is the tank secured - bolted to the floor?
11-19-2013, 11:36 AM | #13 |
Rep 180
Ok. The tank is strapped in. The straps are secured by the metal brackets under the liner. You'll find them when you take the liner off. You can actually see two of them in the fourth photo. I'll try to remember to take more photos if you are interested?!
11-19-2013, 12:35 PM | #14 |
112
Rep 2,621
That would be great.
11-24-2013, 02:10 PM | #16 |
Rep 180
A few more photos of trunk as promised.
E90 M3 ZCP 2010
11-24-2013, 03:01 PM | #18 |
193
Rep 6,110
Drives: Don't know yet!
I've been known to drink it, as I'm sure others have.
Does that help?
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience. |
11-24-2013, 03:56 PM | #19 |
33
Rep 650
l also want to run meth on my 330d in place of changing the intercooler! Looks quite easy to install but just not managed to push myself to buy one yet
