Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E90 19x10 all around Mounted
      11-12-2013, 11:55 AM   #1
Bigv
Drives: 2007 335i
Just thought I'd share for possible e90 owners looking to go 19x10 all around.
19x10 +32 offset
5mm spacer in front to clear
No spacers in the rear (will be putting 25mm spacers soon, just need to roll/pull my fender as it will rub)
245/35/19 in front
275/35/19 in rear
      11-12-2013, 12:00 PM   #2
bmw325i
223
Drives: 2006 BMW 325i
Looks good just needs a spacer in the rear to match the front. The front is actually an easy fit. Et7 with a 275 is going to take some work though good luck.
      11-12-2013, 12:04 PM   #3
Bigv
Drives: 2007 335i
Yessir!
I believe the spacer is actually a 20mm, but nonetheless I tried it on when I was mounting the rears, and it rubbed but not horribly. Some fender pull/roll and camber + alignment should do the trick and look aggressive. (hopefully, if not Ill get a smaller one like 15mm
      11-12-2013, 12:19 PM   #4
wdeerfield
A family of bimmers
2748
Drives: '18 G01 X3M40i
lets see a shot from the front to see how much the front really pokes. its easy to hide it from the angles you posted.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      11-12-2013, 01:22 PM   #5
ianbiz
Back in a BMW
ianbiz's Avatar
205
Drives: 2015 335i Msport
The front looks like it pokes alot. How low are you?
Ian
      11-12-2013, 04:27 PM   #6
bmw325i
223
The front should poke about 11mm. The rear should about be about 14mm with a 20mm spacer
      11-13-2013, 12:12 PM   #7
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
So far looks good. Would look even better if the wheels would be silver. Isn't your rear tyre 275/30/19? Need more pictures.
      11-13-2013, 01:56 PM   #8
Hybrid For Life
Germany
79
Drives: Out of Spec
I like were this is going! More pics!
You'd be way better off just trimming the rear fender lip off, rolling and pulling(bad idea) aren't going to get you much due to the way the rear fenders lips on e90's are made. trim it, sand it smooth, seal it, done.
      11-13-2013, 02:44 PM   #9
ThaiRacer
Drives: 07 335i
For you lowered guys did you guys remove the front plastic lining?
      11-14-2013, 03:06 AM   #10
Hybrid For Life
Germany
79
Drives: Out of Spec
Nope
      11-14-2013, 03:13 AM   #11
Route 16
I got lei'd
Route 16's Avatar
Philippines
845
Drives: '10 E90 M3
baws
