11-05-2013, 09:49 PM | #1 |
131
Rep 458
1/4 Time from Atco Raceway tonight
Went to Atco tonight to run my car and was happy with the results! 2013 335i xdrive with MPPK 8AT 18" 400m w/ oem all season tires. Each run was in Sport + I also used the paddle shifters shifting at 6k rpms.
Best E/T: 12.965 Best MPH: 106.50 Best 60': 1.817 When Motor Trend came out with an article with the same set up they posted a 13.0 @ 105mph so I was hoping to at least match that time. I was skeptical that they may have pumped up the numbers. 12.9's not bad for a grocery getter
Alpine White '16 M3 6MT
11-05-2013, 10:48 PM | #2 |
159
Rep 1,136
nice times! did you have to do a burnout before the run? is that normally required? i would feel embarrassed if i had to do it and messed up and not put up smoke lol. did you hold the traction control for a few seconds on sport+ til you saw the dsc go off?
sent from bimmerpost Android app
11-05-2013, 11:05 PM | #3 |
131
Rep 458
Thanks! No need for a burnout since its an awd car and impossible. The point of a burnout is to heat up the tires for increased grip. Typically you'd want a drag radial similar compound tire and a rwd car. Not the end of the world if you messed up people do it all the time. I just pushed the button to sport then one more time for sport +
11-06-2013, 09:58 AM | #5 | |
131
Rep 458
11-06-2013, 07:47 PM | #6 |
194
Rep 3,780
1.8 60ft is what had you breaking into the 12s. Describe your launch technique(rpm).
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
11-06-2013, 08:01 PM | #7 | |
131
Rep 458
11-10-2013, 11:52 AM | #8 |
131
Rep 306
we just took my wife's stock right off the floor 2014 335 Gt to the track - cut a 13.45 with 104 and a curb weight of 4010 = expect to be in low 12 next spring with a couple of mods - pretty impressive for that car - I race a 13 mustang GT and am mid 12 with minor mods. That bmw could end being a bracket beater for sure - never live it down with wife may have to go Nitrious.
11-10-2013, 04:34 PM | #10 | |
131
Rep 458
Thanks, the AWD is great just look at those 60' times, I had traction off and was told by some guys at the track I was still spinning off the line. Those oem runflats will be gone soon, will be interesting to see if I can improve with wider and sticky tires.
11-12-2013, 02:23 PM | #11 |
78
Rep 1,793
very nice, i wonder how it would compare to same car with 6 MT. and JB stage 1 (a bit higher power output then mppk)
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
