335i - What oil are you using at the track/daily
10-29-2013, 05:58 PM | #1 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
As the title says, just seeing if there is any kind of general consensus as to what the 335i owners are using for oil in their track driven cars. I have been using M1 0w-40 for some time now, but have been thinking of switching and can't quite pin down what I want to go with. Any thoughts or insight is appreciated.
10-29-2013, 10:45 PM | #2 |
32
Rep 290
Drives: E92 335i
Fresh oil... It might be a good idea to go somewhat heavier than stock to deal with the inevitable high oil temperatures:
All-around and track Any good 0W-40 or 5W-40 synthetic that meets minimum requirements (API SM) Castrol 5W-50 Mobil 1 15W-50 Specifically for track use: Castrol TWS 10W-60 Liqui-Moly 10W-60 Motul 10W-60 I for one would not track on the 5W-30 OE oil. It may be OK on the street but at 300º F oil temps I'd feel a lot better with a more viscous oil. You don't need to use an oil that meets BMW LL-01 unless you want to run extended drain intervals (more than 7.5k mi).
For Sale: 2009 335i 6MT (E92/N54), Sport / M-Technic / no iDrive / Black Sapphire / Black Dakota Leather, ZCW, 6FL, PDC, 19" VMR VB3, Pilot Super Sport, M3 control arms + tension links (fr) S. California Last edited by NoTempoLimitN54; 10-30-2013 at 09:38 AM.. |
11-05-2013, 11:42 AM | #3 |
king of the hills
92
Rep 2,915
bump for more input
11-05-2013, 11:51 AM | #4 |
38
Rep 864
Drives: '08 E92 335i
I use the Mobil 1 0w-40. We don't see temps high enough to even faze this oil. I've seen a max of 275F on track. Change it after 2-3 track events.
11-05-2013, 01:05 PM | #5 |
Rep 137
As far as i know, changing to denser oil will "open up" your engine a bit.. meaning you are speeding up its ageing proccess... denser oils should start to be used when your engine has started to consume oil, due to it being a bit "looser" because of its to age and miles run... i personally prefer to make oil changes more frequently and stay with 5-30w than going denser prematurely...
As for oils, here in europe the only one truly 100% sintetic are motul oils. Sorry for the lack of "technical" words... my english is not that good! Hope it helps. |
11-05-2013, 02:10 PM | #7 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
There was a spec sheet on the M1 0w40 on the m3 forum, it has one of the highest temp ratings out there. I stick with that on my 330i, but needless to say the oil doesn't see the temps of a turbo car.
11-13-2013, 05:14 PM | #9 |
1559
Rep 4,109
Drives: BMW M3
I switched to Total 10W-50 on track. Never had a problem with the OEM 5W-30, but I figured a little more high-temp friendly oil wouldn't hurt.
Total 5W-40 in the winter/off season. http://store.vacmotorsports.com/tota...oil-p1881.aspx
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
05-05-2014, 06:48 PM | #11 |
How you like them apples?
40
Rep 1,492
Drives: 335i
stock oil
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
