BMW Performance Powerkit variant 2
10-28-2013, 10:43 PM | #1 |
66
Rep 1,131
Has anyone got any feedback on using the PPK hardware in relation to improving cooling at the track?
I am talking about the additional radiator, more powerful fan and additional airflow ducting. Not interested in the software changes. p.s. this is for a 2007 335i MT with oil cooler |
11-05-2013, 03:41 AM | #2 |
Rep 137
Well i tracked my Car 2 weeks ago with the next mods:
Adittional water radiator from ppk1 335is ducts, so both coolers really get some air and an intercooler upgrade.. I was able to do 40 laps to the track (3 laps wot, 1 lap to refrigerate the Car and stopping for 15 mins every 12 laps) an the car behaved like a champ... Didn't say a word... I did all these upgrades bc last time i was there i couldnt enjoy it because it overheated too fast... I dont have the rad, but i think is not necessary for track use (over 40 mph the air will come fast enough anyway) Mine is a n55, but i think pretty much everything i said is valid for an n54. Hope it helps! |
11-05-2013, 01:38 PM | #3 | |
66
Rep 1,131
11-05-2013, 04:12 PM | #4 | |
Rep 137
Maybe the actual tune is what you can't get but i seriously doubt it also... you can find it for all 335i models at shopbmwusa.... Again, a power rad will only help you at very low speeds... i skipped and don't regret it... my car performs fine without that 900$ upgrade... now, the rest of the bits (335is ducts, extra water radiator & intercooler) I recommend them from first hand experience... they do deliver tangible improvements. Good luck! |
11-05-2013, 05:23 PM | #5 |
66
Rep 1,131
I don't think they do the hardware only without changing the DME....I have an aftermarket tune so not sure it wouldn't overwrite that. Anyway it's too hard so I will look at other options
11-05-2013, 05:51 PM | #6 | |
Rep 137
But hey, if you feel other options are better go for them... keep us informed about what you end up doing! |
11-05-2013, 06:15 PM | #7 |
66
Rep 1,131
Actually you've convinced me that maybe I just need to be a bit pushier with the local dealer, or maybe explore it through Turner Motorsport or another 3rd party.
Thanks again for the advice |
11-05-2013, 08:55 PM | #8 |
38
Rep 864
Drives: '08 E92 335i
Don't think the PPK radiator is really needed, log your water temps on the track, mine are not going above 106C. Oil temps could be a little lower, I have a large oil cooler (stett stg 2) and still see 275F oil temps.
Spend your money on big oil cooler, for MT cars the water cooling capacity is fine. |
11-06-2013, 10:46 AM | #9 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Plus ultimately getting cooler Oil Temps will help with the water temps.
11-06-2013, 12:38 PM | #10 | |
Rep 137
Yep, if your car is manual, the additional water cooler might not be essential... For DCT guys like me, it is good though, part of the gearbox is cooled by water... The stett Oil cooler would be my preferred choice also... it has glowing reviews and the core looks quite big... I don't know why nobody has come with an upgraded core that uses the oem lines for the oil cooler... it would be cheaper to produce, more affordable and thus, they would sell a lot more of them... Also guys like me who are still on warranty could use it without having to worry about the dealer... |
11-06-2013, 01:09 PM | #11 | |
38
Rep 864
They probably aren't going to do kits this way because there's very little hardware required other than the core itself, so little profit for a shop. Just go get it done locally, its not a difficult job. The reason for the upgraded lines and fittings on the oil filter housing is the factory fittings and lines are rather small and don't flow that much oil. But it should still work ok - certainly better than the stock cooler. |
11-06-2013, 01:48 PM | #12 | |
Rep 137
I got a low thermostat from BMS... let's see if it brings any improvements... (i highly doubt it).. But you pointed out something i didn't know... the insuficient oil flow due to small lines and filter housing... Then i don't think it will make sense to improve only the core... That would only solve part of the problem, and it would be very likely that my temps would remain high... |
11-06-2013, 01:50 PM | #13 | |
38
Rep 864
11-06-2013, 01:52 PM | #14 | |
Rep 137
Thanks again |
11-14-2013, 02:44 PM | #15 |
Rep 371
Drives: 2017 BMW M3 30 Jahre
