Horrible Time Slips
10-28-2013, 09:55 AM | #1 |
26
Rep 266
Horrible Time Slips
I sent my JBD in to be tested as I have horrible 1/4 and 1/8 mile times with it installed. Not sure if it was bad or what, but Terry said "I noticed it had an older chip so I updated that. Tests out OK now. We'll get it back out today". This was Friday. So I am hoping my JBD wasn't functioning properly.
Notice that even with a 2.0 60', I still ran a 14.x @ under 100mph. Am I the only one that sees a problem here? These are the slips from the 1/8 mile track on October 10th. 70 degrees. JBD @ 100% These are the slips from the 1/4 mile track on August 31st. 88 degrees. JBD @ 100% |
10-28-2013, 10:35 AM | #2 |
41
Rep 800
Hey bro with those reaction times you gotta quit sleeping at the wheel. :P
I got the flash and those are about the times i get in the 1/8. I did break 9 sec twice... ill scan in that on slip that i went 8.82 |
10-28-2013, 10:39 AM | #3 | |
26
Rep 266
P.S. - The last yellow time slip is what happens when you hit limp mode halfway down the 1/8th...haha |
10-28-2013, 06:18 PM | #4 |
Rep 88
8.8 and ~82 mph on the 1/8 is ok, but 100 mph on the 1/4 is too low.
I have always 104-105 mph on the 1/4. My worst time was 13.65 104 (88f) and my best was 13.11 @ 105 (66f) My time are all between that and the temp dont have a big effect on my time with this car... Very consistant run after run . |
10-28-2013, 07:59 PM | #5 | |
26
Rep 266
11-02-2013, 01:23 PM | #8 |
Warrant Officer
375
Rep 1,341
Did you notice a difference? I was only trapping 100mph in the 1/4mi with 100% JBD. I bought mine back in August of 2012.
Deleted, ATM I/C and tuned by B.R.R.
11-04-2013, 09:57 PM | #9 |
26
Rep 266
I think it's actually slower than it was. I now tie with a friend who I used to beat pretty good. It's a stock 2003 M3 convertible. So heavy with 330HP.
11-05-2013, 02:37 AM | #11 |
822
Rep 3,980
Did any of you start having these problems after the EGR recall? Also, it seems our engines have varying performance depending on the DPF restriction. See my other post below:
http://www.e90post.com/forums/showpo...0&postcount=42 Also realize heat soak, warmer temps seem to kill performance. For best results you want to be running below 65F or so ambient temps.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
