10-26-2013, 04:26 AM | #1 |
15
Rep 195
coding help (CAS module read error)
About video in motion, I am not sure it is my car build, I follow instructions to the grid, the handbreak section, speedlock min/max, but still could not get it to work, any tricks I've been missing?
F10 M5 Juy 2012 build I also encounter an error when reading code data in ACM module, it said something about file not found, that's annoying because that's where auto start/stop is I could get TPMS and sports reading to work though Last edited by lumberman; 10-27-2013 at 09:36 AM.. Reason: more specific |
10-26-2013, 06:15 AM | #2 |
18
Rep 103
Start stop is in the CAS module:
CAS => 3000 => TC_MSA_MEMORY => aktiv. Change it to aktiv if you want it to remember the last setting. Or if want it off permanently, change the below to aktiv: CAS => 3000 => TC_MSA_DEFAULT_OFF => aktiv For DVD in motion I have not tried it as its not something that interests me. For 2012 do you have CIC or NBT? Probably CIC. 2011-12 (CIC) HU_CIC => 3000 => SPEEDLOCK_X_KMH_MIN => value = FF HU_CIC => 3000 => SPEEDLOCK_X_KMH_MAX => value = FF HU_CIC => 3000 => VIDEO_NUR_MIT_HANDBREMSE => nicht_aktiv 2012-13 (NBT) and 2014 LCI HU_NBT => 3000 => SPEEDLOCK_X_KMH_MIN => value = FF HU_NBT => 3000 => SPEEDLOCK_X_KMH_MAX => value = FF HU_NBT => 3000 => VIDEO_ HANDBRAKE => nicht_aktiv Are you saving the file after editing it, then go back into expert/coding to apply it to the module? |
10-26-2013, 11:16 AM | #3 |
15
Rep 195
you are right, auto start/stop is in CAS module, that's where I encounter error reading file
I am not sure whether I have CIC or NBT, I will try look for the NBT value tomorrow, in case I do have a NBT I save after I changed the value of speedlock min/max, handbrake section, then use the back button to expert/coding mode, activate FA, then select that module and code FDL, am I missing something here? I could get trunk open from driver side button, tpms reading, sport gauge to work though Thanks for the hint |
10-27-2013, 09:31 AM | #4 |
15
Rep 195
anyone out there also encounter error while reading code data from CAS module?
I got everything else coded, except VIM and disable auto start/stop, any help would be greatly appriciated thanks, |
10-28-2013, 09:27 AM | #6 |
15
Rep 195
v12,
I've been trying to reach you by PM, I think it has been blocked I text your cell too, but maybe it didn't went thru where do I get the latest/correct CAFD for my car? I switched on my car the whole time and notebook battery is not a problem. any help appriciated Jeff |
10-28-2013, 12:51 PM | #8 | |
Internet Crash Test Dummy
331
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
http://www.f30post.com/forums/forumdisplay.php?f=429 He'll provide you with a download link for the light or full files (only needed if you want to flash modules) and the RAR extract password
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
10-28-2013, 01:04 PM | #9 |
15
Rep 195
Thanks jmh,
I did get the files from shawnsheridan, (thank you by the way shawn) I am working with esys 3.23.4 and 50.4 psdzdata, somehow it still doesn't have the correct CADF for CAS module Last edited by lumberman; 10-29-2013 at 12:51 AM.. |
