F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > M-Sport lower left and right grill removal
Extreme Powerhouse
      10-21-2013, 07:13 PM   #1
Axman85
77
Drives: 335i x-Drive M-Sport Min. Grey
Anyone know how the lower left and right grills pop out (US Spec with no fog lights) of the M-Sport? Have a bunch of leaves covering the oil coolers behind them.
      12-26-2013, 08:00 PM   #2
Infamouz627
Infamouz627's Avatar
41
Drives: 2013 335i M-Sport EBII 6MT
Looking for a solution to this too. Grills will probably be a pain to remove if removable at all. Any others have alternate methods to removing leaves and other foreign bodies stuck back there?
2013 EB2 335i M-Sport 6MT // BM3 Stage 2 // VRSF DP // AA CP
      12-27-2013, 12:57 PM   #3
Axman85
77
Seems like we're the only ones who get crap in there. Since there haven't been any replies I'm going to see I I can figure out how they are held in place.
      12-27-2013, 09:30 PM   #4
mcalc55
32
Drives: '13 F30 328xi BSM M Sport
Hey man, the grilles are pretty frustrating to remove but definitely do able. follow this link:
http://www.f30post.com/forums/showthread.php?t=701830
I just did mine this morning. Follow the instructions and make sure you push the smaller middle piece of the tab because that's what's keeping them in line. I was pushing the outer piece and not getting anywhere. Also, I ended up breaking quite a few tabs in the process, but since i was putting the black grilles in i didn't care as much.
I recommend you follow the first half of the DIY there and just remove the screws so you can get behind the grille and then remove your leaves. You don't need to remove the grille and risk breaking any tabs.
That being said...plenty of people are able to remove the grilles without breaking tabs, i just wasn't one of them..YMMV
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats
      12-31-2013, 10:11 AM   #5
Axman85
77
mcalc55,
Thanks for the DIY. I'm hoping I don't have to take the nose apart to get Ito this space from above. I am trying to pop these out. If it weren't so cold I'd mess with. May need to wait until spring.
      01-11-2014, 06:26 PM   #6
mhanism
mhanism's Avatar
277
Drives: 2020 M2C
What color is your M Sport?
MY20 M2 Competition
MY16 M3 (Sold)
MY17 X3 35i M Sport
MY14 335i M Sport (Sold)
      01-11-2014, 07:55 PM   #7
Axman85
77
Mineral grey
      02-19-2014, 05:27 AM   #8
Vitoco
Infidel
Vitoco's Avatar
122
Drives: iX3 LCI M Pro Carbon B
mcalc55,
how did it go, found an easy way yet?
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      02-19-2014, 07:26 AM   #9
Axman85
77
Been to cold and snowy in MA to mess with it. Waiting for the big thaw.
      05-27-2014, 05:49 AM   #10
Axman85
77
Instead of removing the grill I manage to get a thin nozzle for my shop vac that slides between the grill. Much quicker to vacuum it out that trying to take the bumper apart.
      05-27-2014, 11:04 PM   #11
GentlemanDriver
Drives: 2013 BMW 328i F30 M-Sport
Just get some tweezers and take out each leaf one by one... get 2 pencils and use the erasers to pul leaves out..
Move them with pencil eraser and use tweezers to take them off. Get it vacuumed..
so many options lol
      04-16-2019, 11:34 PM   #12
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
Use a vaccuum cleaner with the thin attachment. Sucks right out.
Also, if i remember right, when I was replacing the horn...you can also pull the wheel off and undo the wheel well cover with a few 8mm bolt/screws. Then you can gently tug the cooler back and debris just falls down. (See this youtube video I did...
      05-16-2019, 06:38 PM   #13
LIVY435IGC
21
Drives: 2015 435i Gran Coupe
On this topic, any ideas on replacing these lower grills?
Something not oem, all of mine have cracks here and there.
Wanted to change it up, if i was going to replace.
      05-16-2019, 10:06 PM   #14
exE36M3
BMW CCA Member
exE36M3's Avatar
488
The sell metal mesh grills like this
Easy to trim and size.
      05-16-2019, 10:12 PM   #15
LIVY435IGC
21
Thanks will look into that
      05-30-2019, 03:06 AM   #16
SilkySmoooth
30
Drives: '13 335i MSPORT Estoril Blue
I wondered how I was going to clean all that crap out when I bought my car.
I have the easiest solution for everyone!
Just use a high powered blower at different angles and it blows these leaves right out. Angle the air from the left, right, top, bottom etc, keep moving the air around and after a minute or so, CLEAN!
      05-30-2019, 12:25 PM   #17
silver.f30
Drives: 2015 335i - Glacier Silver
I'd also be curious how to remove these. I can't stand the dull black color in contrast with my gloss black kidney grills, so planning to remove them and repaint
      06-07-2019, 10:26 AM   #18
gdgraph
gdgraph's Avatar
102
Drives: 2016 340i xDrive
If you have access to an air compressor you can blow the leaves off of that, or just take an old rag or sock and put it over a thin vacuum cleaner nozzle and go in and surgically remove the leaves that way.
f30post
