optimum volume level iphone/head unit?
10-19-2013, 11:19 PM | #1 |
65
Rep 515
is there any consensus as to the best iphone volume level and head unit volume level that will give the cleanest sound from the speakers?
i have noticed a difference in volume and more importantly the "adjustability" of the volume (for lack of a better term) depending on how high/low the volume is on my iphone when using Bluetooth/lightning cable any thoughts? thanks |
10-19-2013, 11:48 PM | #2 |
362
Rep 1,407
Drives: 13' F30 328i 6MT
If your going into the AUX 3.5mm port I have best results with the volume in the middle on the decks AUX VOL setting and be sure to NOT use a 3.5mm to 3.5mm wire but rather use a DOCK to 3.5mm cable.. You do not want to go from headphone to aux, I cannot give you a good recommendation for that.
http://www.amazon.com/Neewer-White-3.../dp/B005DISKZQ If your on an iPhone 5 or above you'll also need an adaptor like this : This will give you way better sound and wont cost more than $30
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
10-19-2013, 11:56 PM | #3 | |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
10-20-2013, 08:29 AM | #5 |
362
Rep 1,407
Ahh yes I assumed you didnt have USB when you mentioned AUX... If you have the USB port, Lightning to USB is the way to go 100%
10-20-2013, 11:47 AM | #6 | |
223
Rep 5,120
