INPA error codes decoding?
10-15-2013, 07:50 AM | #1 |
Rep 126
Hey guys,
I just found a bunch of error codes out of my car that i can't understand. I believe the codes are in HEX and when i converted em to decimal, there are way too many digits (i.e. CF14 = 53012), that 53012 decimal code doesn't relate to anything based from http://www.endtuning.com/bmwcodes.html Here are the list of my error codes pulled from last night: DME/DDE - 2AD8 - A4 EGS - CF14 - 24 DSC - 5DEC - A0 - D35A - A4 TEL/MULF - A379 - 20 CAS - A0B0 - 21 - A10A - 22 - A107 - 28 FZD - A670 - 28 KOMBI - A554 - 20 - A3C3 - 20 - A3B2 - 20 MOSTGW - E194 - 20 FRM - 9CD4 - 64 - 9CD5 - 64 I just need to know how convert those hex codes into information. Any help would be appreciated. |
10-15-2013, 08:36 AM | #2 |
Rep 81
You can choose each module spearately to test and you will see more details about it.
Just select your chasis and select your engine, then select F4 Read Codes and then F1 (I'm not sure now but something like that. You can do the same with all the rest e.g. KOMBI (instrument cluster). |
06-18-2015, 03:36 AM | #3 | |
LOADING...
Rep 30
I can not find any information about that "A107" error code, anybody know wtf is that ?
06-18-2015, 03:41 AM | #4 | |
LOADING...
Rep 30
odd...mine and your CAS error codes exactly the same :
A0B0 - 21 A10A - 22 A107 - 28 Could you find whats that? My problem is engine bouncing/hesitation at 2000RPM when driving, it was similiar as your? Quote:
08-04-2017, 03:29 AM | #5 |
42
Rep 192
If anyone comes across this thread in the future, here's some of the codes:
FRM 9CD4 - Communication with seat-belt handover, driver's side, disturbed 9CD5 - Communication with seat-belt handover, passenger's side, disturbed DME 2AD8 - EAC sensor,monitoring DSC 5DEC - DSC: Transfer case: malfunction CAS A0B0 - Input, brake lights, implausible A107 - Coachdoor locking,passenger's side, deactivation FZD A670 - FZD: Signal line, fogging sensor |
Tags |
decode inpa., error codes, fault codes, inpa |
