How does BMW not equip all their vehicles with this??
10-13-2013, 04:14 AM | #1 |
Member/ E92 Owner
Rep 136
I think, not positive, that my E92 does NOT have an alarm?? Crazy..
How is this possible? I was searching for the "noise beep" when locking the car because mine was not acquiring the sound. I found that I could locate this in the iDrive under the "Door Locks" settings although it is NOT there. If I remember correctly to sound the alarm on these cars you press and hold any button on the remote, although again nothing happened. What am I missing here..? Do I need a software update? The car's sticker price was $55,000.. AND THERE ISNT EVEN ANY SECURITY FOR IT?? Do ALL BMWs not come up with an alarm or "noise beeps" when locking? Is it an accessory that they have but not available as an optional package? What package would this be? |
10-13-2013, 06:34 AM | #2 |
78
Rep 1,038
Alarm is optional. I know, I know. They insist the car is impossible to start without the FOB, so it became an option just liked power seats. I've heard its not that expensive to add though.
10-13-2013, 08:04 AM | #3 |
13
Rep 121
Don't bother with an OEM alarm anyway
It takes less than 5mn to make a duplicate key and start the car and go away with it. With OEM alarm or not. You do not even need to have one of the original keys to make a new one. Get a GPS tracker instead. And put "GPS Tracked" kind of stickers on the windows. Use a steering wheel lock whenever you can too. |
10-13-2013, 08:18 AM | #4 |
62
Rep 944
I checked my vin and checked under the bonnet for the alarm switch. Both present for alarm. So I proceeded to code my ride and got the panic alarm and beeps .....
Suggest you check if the alarm hardware is physically installed first .... |
10-15-2013, 09:27 AM | #7 |
13
Rep 121
10-15-2013, 10:06 AM | #8 |
555
Rep 1,244
Drives: 2013 F10 M5
10-15-2013, 04:31 PM | #9 | |
20
Rep 48
Here in Norway you used to get a discount on your car insurance if the car had alarm installed. This discount was removed a few years back, probably because nobody bother to even turn their head if they hear a car alarm go off. 95% of the time it is a falls alarm.. I would't spend a dime on a car alarm. GPS tracker though, different story Last edited by OveN; 10-15-2013 at 04:37 PM.. |
10-17-2013, 04:53 AM | #10 |
No 55mph
1622
Rep 8,476
Easiest way is to look on cowl, underhood, below microfilter housing for the hood switch:
If you have this switch, then more than likely, you have the alarm hardware installed. But frankly, I have never heard of a BMW actually having all the hardware installed & just needed coding for it to be activated... Alarm is an option, you either have all of it & it is coded to be active, or you have none of it. BMW does not make a habit of installing hardware for options & then just simply not 'turn them ON' - not cost effective. If you don't see the hood switch, you still can add the alarm system for around $275. But there are again certain 'restrictions'
When you are looking for that Hood Switch, if you don't have one, still check to see if you have that pigtail wire with connector that goes to the switch as shown in the above pic. If not readily visible, it may be wrapped out of the way in the main harness very close to that area. If you do have that wire, then more than likely your car is prewired for alarm My 09' with Build Date of 2/09 did not have the alarm originally, but was prewired. I picked up an alarm system from forum member for $100, installed all PnP, and coded it to be active. I wouldn't have even bothered if the car was not prewired...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-23-2013, 11:32 PM | #11 | |
Member/ E92 Owner
Rep 136
