10-11-2013, 11:04 AM | #1 |
210
Rep 2,110
Lumbar Support Solution - Now installed!
I know, should have got the premium package... I need to find an inflatable bladder, any recommendations? Also, my 2013 328 has heated seats. Does anyone know if the heating pads are attached to the seat back OR if they are located underneath the cushion? Thanks
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi Last edited by GreenThree; 10-24-2013 at 01:46 PM.. |
10-11-2013, 12:43 PM | #2 |
1538
Rep 3,331
You'd be much better off trying to find a totaled car you can gut the seat out of and not try to stitch things together yourself.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
10-11-2013, 04:04 PM | #3 |
210
Rep 2,110
^ Not a bad idea, but too much time and effort involved. I found an inflatable bladder from Corbeau for $49. It has a manual adjustment (illustrated in pic above) and can be placed fairly easily in the seat back. Anyone have experience with this? Hoping it does not interfere with the heating elements in the seat. Thanks
10-11-2013, 04:17 PM | #4 |
5697
Rep 3,225
When the 350z first came out I bought one and the seats in it were atrocious. I ended using a bladder similar to the one you have shown and it worked a treat.
It didn't interfere at all with the heated seats and was simple enough to put in and use. |
10-12-2013, 03:16 PM | #5 |
210
Rep 2,110
^Helpful post, appreciated!
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi |
10-24-2013, 01:58 PM | #6 |
210
Rep 2,110
Just a quick follow up for those that have the standard seats, which are terrible BTW. The part pictured above was $49. Install was $75. The newly installed bladder feels EXACTLY like my last 3 series which had the factory lumbar option. Saved $3,000 in the process too! I discovered the heating pads are glued to the seat back, so anyone looking to do this can simply take the rear plastic cover off, and slide the bladder behind the metal coil springs. What an improvement - My car is now the Ultimate Comfort Machine!
11-01-2013, 08:41 PM | #7 |
Rep 39
Thanks GreenThree! The lack of lumbar support (power or manual) in the standard seats is also a problem for me. I might choose the sunroof option, but I don't want Comfort Access which accompanies power lumbar in the $3,100 Premium package. The May 2013 post by mtherr, who installed the OEM power lumbar for $600, is amazing -- but I don't think I can pull that off alone. Your update is really helpful. Where does the bulb wind up exposed in your installation? Also, did you need to buy new fasteners for the seat back cover?
11-04-2013, 07:43 PM | #8 |
210
Rep 2,110
The bulb rests in between the center console and the drivers seat, so its out of view and not noticeable. I did not need to buy new fasteners for the seat back cover.
UPDATE: At first glance, this bladder appears to be the perfect solution. But after a week, its NOT working. It inflated to full capacity for a week. Now it no longer holds air. I think the tube has slipped out from inside the bladder. I am very disappointed in the product, as this does not work as advertised. Corbeau and the company I bought it from were very good to work with and will refund my money in full. I am working with an excellent auto upholstery shop which recommends a fixed cushion in the back given these circumstances. He returns next week and will get it fitted properly in the seat. Will post an update when that happens. Just wanted to follow up so members looking to do this are in the know.
11-04-2013, 08:24 PM | #9 |
Naval Aviator
Rep 63
I have the Comfort Access option and find the lumbar support fine but the overall support of the seat is terrible. The front of the seat is too small so there is little under leg support and there is minimum lateral thigh support. All cars should be shipped with the Sport seats.
Meatball, Lineup, Airspeed means a successful carrier landing-most of the time.
Ah-those were the days!! |
11-15-2013, 07:16 PM | #10 |
210
Rep 2,110
Update: Upholstery shop made a custom lumbar cushion for my seat. Installed today. Works well and supports my back.
11-16-2013, 12:44 AM | #11 |
355
Rep 1,986
11-16-2013, 08:05 PM | #12 |
210
Rep 2,110
I paid $75 for the job
12-06-2013, 03:18 AM | #13 |
Rep 29
