MULF Unit Failure
10-09-2013, 02:35 AM | #1 |
Rep 46
MULF Unit Failure
Hey all!
My MULF2 unit is dead so until I have enough money to replace it, I was wondering if I can just bypass it in the MOST loop so that all my AUX and stuff works? If so, how would I go about doing this? Thanks! x.dorky! |
10-09-2013, 12:04 PM | #4 |
1911
Rep 13,104
There is a Most Junction Box
There is a Most Junction Box/ Hub behind the rear seat bolster
on the US Drivers side. You can reroute there or just buy a Most jumper and put it right at the Mulf. That will at least close the Most Loop I don't know if the faulty module will throw error messages . There are some DIY's that show this junction box in the DIY section for things like adding the ipod or cd changer . You might be a to kludge a cheap most jumper together with something like a straw and some duck or electrical tape. Find a small tube that just fits over the fiberoptics end piece stick the fiberoptic from input and output of the mulf in the tube tape in place. http://www.e90post.com/forums/showth...ght=cd+changer The above shows the junction box. Last edited by ctuna; 10-09-2013 at 12:36 PM.. |
10-09-2013, 01:40 PM | #5 | |
13
Rep 121
I use part number 4 below when I come across this kind of issues in customers cars, and hell those issues are too common. Remove the MOsT plug from the BT module, unclip those 2 green wires and join them in the part 4 (BMW part number 61136906535) from the picture (Or similar) Or use the suggestion made by CTUNA. It is good too, but personally I have lots of spare part 4 and I don't bother as it can be tricky to unclip this "junction" box for the Most connectors. |
10-09-2013, 06:12 PM | #6 |
Rep 46
10-10-2013, 03:08 AM | #7 |
13
Rep 121
05-29-2018, 09:37 AM | #9 |
Rep 1
Drives: 2009 328i convertible (e93)
MULF Bypass caused AUX failure
I successfully bypassed my MULF Unit (underneath the TCU unit) in the trunk of my 2009 e93 (328i convertible). I purchased the recommended fiber optic jumper cable, modified it as directed on various forums, and secured it to the MULF fiber optic connector.
As a result of the bypass, I've lost AUX input (under the center arm rest). I don't think I have lost any other functionality that I desperately need, but I would really like to connect my phone to my car speakers (likely via AUX cable). It seems like it may be possible to connect an AUX cable to the head unit? By the way, I have nav/iDrive. Thanks for any ideas or guidance on recovering AUX functionality without replacing my faulty MULF unit. -Mike |
05-29-2018, 02:51 PM | #10 | |
456
Rep 2,749
another option - you can buy MULF2 unit pre-coded to you options list, from qualified electirc, simply replace failed and everything should work
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
06-07-2018, 09:44 PM | #11 |
Rep 3
where do you look for the mulf2 precoded?
06-08-2018, 04:44 AM | #12 |
1911
Rep 13,104
both aux and usb come from the mulf in a lot of cars.
Blue tab on Fiberoptic connector is the locking pin see video. Last edited by ctuna; 06-08-2018 at 04:51 AM.. |
06-08-2018, 07:40 AM | #13 |
456
Rep 2,749
i can sell precoded MULF2HIGH unit to you
