folding mirror not working
10-06-2013, 10:56 PM | #1 |
43
Rep 420
ok so yesterday i did a coding in NFRM to turn on low beam on when unlock. some reason it didnt work right so i went expertmode and got back to default. now my folding mirror wont work with switch where its located with windows switch.....is there a coding to turn my mirror back on? i couldnt find them...thanks
12-05-2014, 06:59 AM | #9 |
161
Rep 2,399
i have same problem! i installed frm2 into my car to have welcome lights, it looks all coding is ok but now my mirrors will not work at all. no movement from switch at all no heated or folding. can anyone help with ideas?
12-08-2014, 04:36 PM | #10 | |
41
Rep 328
Did you copy the vo from cas to nfrm? If you have a pre-lci you should simulate the date (#0307) because than you can pick nfrm from the modules list iso frm. |
12-09-2014, 03:18 AM | #11 | |
161
Rep 2,399
12-09-2014, 04:28 PM | #13 |
41
Rep 328
12-09-2014, 06:32 PM | #14 |
529
Rep 2,503
Teq, cryptomit
I'm glad you came up on this thread. I tried to help cupraraj remotely and everything seems in order, maybe I missed something though. I've never seen this problem after FRM upgrade... For active LIN bus is; ASP_LIN_VERBAUT aktiv ???? In which case I believe I checked this and it was aktiv. Was there some pin change on FRM2 for LIN bus? Pin 22, 23 for drivers door cluster and passenger mirror? This problem is really bugging me and it's not even my vehicle lol!!!! One thing I noticed I'd actual date in VO has been written to VO in CAS and NFRM, rather than just simulating? Could this cause a problem on LIN BUS? |
12-10-2014, 03:19 AM | #15 |
161
Rep 2,399
12-14-2014, 02:13 PM | #17 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
I found the best thing to do is take a backup before changing the PSW! if you haven't after modifying the coding and stuff isn't working properly there is something you can try. It is dependent that you VO is accurate for your car! In NCSExpert do a "SG_RESET".....Then change the job to "SG_CODIEREN" but make sure your "PSW" file in C:\NCSExpert\WORK is completely empty. This codes nothing into the module which makes the car update the module based off equipment and VO. You may have to recode custom stuff back but the FRM will be setup to your car properly which should re-enable your mirror.
12-16-2014, 03:48 PM | #18 |
41
Rep 328
Wiring for the lin bus is the same.
Frm2: X14260 pin 22: outside mirror passenger's side lin bus pin 23: driver's switch cluster Are you sure that the frm2 isn't broken? |
12-17-2014, 08:06 AM | #19 |
41
Rep 328
12-17-2014, 08:32 AM | #20 |
161
Rep 2,399
12-17-2014, 03:57 PM | #21 | |
41
Rep 328
Uhm...blocking? Remove glovebox? I've got a customer who also wants this but I'm going to install it in about 2 monts. I don't expect that their will be issues with it. Please check the fuse and report back. |
