10-04-2013, 03:46 AM | #1 |
58
Rep 194
F32 4-series has grown taller in 3 months?
When BMW released the press kit in June, the height of 4er was 1,362 mm (53.6 in).
And now she’s got 15 mm taller. What happened with her? The press kit (pdf here) stated “a roofline that now runs 16 millimetres lower than before (1,362 mm)” in page 5, and the specification (page 27 & 36) also shows the height = 1,362 mm. But I recently found the technical data on the web shows the height = 1,377 mm (54.2 in).
[ Present ] 2021 BMW M850i xDrive Coupe (G15) [ Retired ] 2014 ALPINA B4 BiTurbo Coupe (F32) |
10-04-2013, 07:18 AM | #3 |
58
Rep 194
She gained weight too
10-04-2013, 08:31 AM | #5 |
58
Rep 194
Just got this email from BMW AG...
----- Dear Toshi, thank you for your e-mail! The data in the press kit is correct. We will check the data in the other source and have it corrected. Best regards from Munich ----------------------------------------- BMW Group Bxxxxx Exxxxx Corporate and Governmental Affairs Spokesperson BMW Automobiles |
10-04-2013, 09:04 AM | #7 |
58
Rep 194
10-04-2013, 10:30 AM | #9 |
6659
Rep 15,858
10-04-2013, 11:02 AM | #10 |
58
Rep 194
Check the press release and the web site in the 1st post.
Both tech specs are on the same 17" rims. Only the body height is different. Last edited by Toshi; 10-04-2013 at 12:12 PM.. |
10-04-2013, 11:19 AM | #11 |
Rep 70
10-04-2013, 11:23 AM | #13 |
Law Enforcer
25114
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
In most cases the overall diameter stays the same (..i.e...larger rim, lower profile tire......smaller rim, higher profile tire). Going from 18's to 19's or from 19's to 20's doing really affect overall diameter.
10-04-2013, 12:22 PM | #14 | |
6659
Rep 15,858
19" wheels are not bigger than 17" or 18". Tyre aspect ratio is changed to get a very similar rolling circumference and wheel diameter. Also the idea that a bigger wheel (rim diameter) fills the fender gap is just an optical illusion, not due to a different wheel diameter. HighlandPete |
10-04-2013, 12:36 PM | #15 | |
197
Rep 2,802
