F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Brake Fluid?
Studio RSR
      10-03-2013, 09:46 AM   #1
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
Brake Fluid?
To those of you that have flushed out the BMW brake fluid and replaced with something with a higher boiling point - what did you use?
      10-03-2013, 12:29 PM   #2
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
ATE, though I ended up back to OE since I had the dealer flush them again. IMO ATE is the best bang for the buck. At least on paper.
      10-03-2013, 01:17 PM   #3
JN1
JN1's Avatar
301
Drives: S211 AMG E63
Motul RBF600
This what I've run in the past and will be flushing mine out to shortly.
-JustinNApproved
      10-03-2013, 04:08 PM   #4
JMK007
67
Drives: 335 M Sport, RWD
From least to most expensive, ATE, Motul 600, and Castrol SRF.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09
Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11
Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19
      06-26-2014, 12:14 PM   #5
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
9720
Drives: M Sport 335i
2014 335i  [9.74]
Is one bottle enough for a complete flush?
      06-26-2014, 12:33 PM   #6
utenigma
162
No, 2 are required if you're changing from stock to something else. Otherwise you'll just have new in the reservoir and old in the lines and calipers - right where you don't want it.
After that, just run 1 bottle through the system every 6 months or after every big track weekend.
BTW I went with RBF600 - works like a champ
      07-12-2014, 09:37 AM   #7
Polo08816
1610
Drives: 2014 335i M Sport
Anyone have a DIY/tutorial or some tools that would make this easier?
      07-14-2014, 12:50 PM   #8
utenigma
162
I posted something here
http://f30.bimmerpost.com/forums/sho...&postcount=149
The Motive power bleeder is awesome for 1 man bleeding
      12-15-2014, 01:40 PM   #9
hgmotorsports
hgmotorsports's Avatar
82
Drives: Drives at Redline
Originally Posted by JNLBC View Post
Motul RBF600
We've used and stocked Motul RBF for years and swear by it! RBF600 for street cars that see track time, 660 for dedicated track machines.
      03-27-2015, 07:34 PM   #10
Car54
36
Drives: 2014 M-Sport Wagon - EBII
2 bottles of Motul is 1L.
ATE is sold in 1L bottles.
      05-01-2015, 11:05 PM   #11
cgarner40
Drives: 2013 BMW 335xi
+1 on the Motive Power bleeder, but get the black label with the aluminum cap and swivel fitting. Best gadget in my garage and worth $70. Can use 2 different methods for bleeding. Cleans easily with Denatured Alcohol from hardware store.
+1 also on the RBF 600. Have also used Motul 5.1 for DD with the occasional HPDE.
      07-20-2015, 07:02 PM   #12
9720
2014 335i  [9.74]
I found one bottle of RBF was more than enough to completely flush the system in my F30 w/ M Sport brakes. I actually have 10% or so remaining.
In the end I did actually use two bottles. I only achieved perfect hydraulics after flushing twice with activating the ABS/traction control a few times between bleeding sessions. I drove a week or so between bleeding sessions making sure I get the valve block in the brake system flushed out.
Along with SS lines, the M Sport brakes feel awesome with a proper bleed.
      09-19-2015, 11:45 PM   #13
Yuqi
10
Drives: 14 335i Xdrive
Don't use ATE racing Blue, it will make a lot of noise from the brake pedal.
      09-21-2015, 10:19 AM   #14
jwilly
Drives: They're all white now.
How?
That's a lot of white
      09-30-2015, 09:18 AM   #15
Vitoco
Infidel
Vitoco's Avatar
122
Drives: iX3 LCI M Pro Carbon B
How bad does the OEM fluid get with normal/inspired everyday driving? Just had my first fluid service last week after 3 years..........
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      09-30-2015, 05:10 PM   #16
utenigma
162
Brake fluid doesn't go "bad" per-se, it absorbs water over time. As the brake fluid gets more and more water in it, it's boiling point goes down. Eventually even moderate braking loads can cause the fluid to boil, the brake pedal goes to the floor and you have no brakes.
OEM fluid is less hydrophilic than racing brake fluid - the trade off is racing brake fluid has a higher dry boiling point
Meaning racing brake fluid is much better when new, resists boiling at much higher temperatures, but absorbs water faster making it last less time.
BMW recommends changing the OEM fluid every 2 years for safety reasons. If you're going with a racing brake fluid, figure every 6 months.
Appreciate 2
Gertsee51.00
      10-01-2015, 02:58 AM   #17
Vitoco
Infidel
Vitoco's Avatar
122
Great reply!
So, why did my car not want it til now? Is the 2-year interval something new or depending on market region maybe?
      10-03-2015, 04:17 AM   #18
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Great reply!
Years ago, BMW used to have yearly changes recommended on brake fluids. Now they changed it to two or even three years. This is not saying anything about the brake fluide "safety" however.
BMW uses glycol based brake fluides DOT4. Don't use DOT5 or you will kill your brake system!
https://en.wikipedia.org/wiki/Brake_fluid
As written the fluid will lower the wet boiling point over the time. You can test the brake fluid boiling point with special equipment.
In any driving/braking conditions you want you brake fluid NOT to reach the boiling point. This will cause gas bulbs in the system and immediate brake power loss. When the fluide cools down, brake will work fine again.
On regular street use a boiling point of 180°Celsius could still be fine, but on heavy track use it could be that this is already to low.
The bad thing is: If you find out, it could be too late
The change interval is good for normal use, but if you track your car, you may want to control the boiling point from time to time.
It is also important to have the brake fluid reservoir closed and sealed. Avoid that water drops get into the system (i.e. from cleaning the engine with high water pressure)
Besides Boiling point corrosion and viscosity are other factors, why brake fluids need to be changed. (as wiki explains)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      03-04-2016, 01:44 PM   #19
lijiahua790
lijiahua790's Avatar
16
Drives: 2012 328i n20
RBF FTW
+1, I even used 660, but generally 600 is more suitable.
Originally Posted by JNM3 View Post
Motul RBF600
      03-17-2016, 09:45 PM   #20
9720
2014 335i  [9.74]
I push a new bottle of Motul through my car every time I switch summer/winter tires; and before and after any time the car goes on track. Sometimes I'll rotate MTL Blue just so the color change (Motul is clear) proves I pushed the old juice out.
      03-22-2016, 10:55 AM   #21
MickAv8r
MickAv8r's Avatar
175
Drives: 2014 EBII 328ix
Lots of people I know love the Castrol SRF because they change it less, I've been very happy with 600 RBF.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      07-14-2016, 12:57 PM   #22
Official NOCO
NoCo's Marketing Pawn
27
Drives: 2014 Mazda6 GT - I mean a BMW?
Anyone recommend a good oil for hot Arizona summers? It gets upwards of 120 here and we have to change oil more frequently because of it.
f30post
