Connector Help
10-02-2013, 10:57 PM | #1 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Connector Help
Hey guys,
I am looking to upgrade my speakers and amp with some new equipment. I know there are some already made, but I just wanted to see what it would look like to create my own (this will determine whether or not to just buy one. Like man I do not want to cut up the stock harness, so I am looking for the following and if you could help me that would be great. I have a E92 and looking to buy the connectors (male and female) for each speaker. 1. Front Doors with Tweeter (male and female plugs) 2. Under seat subwoofer (male and female plugs) 3. Tweeters (male and female plugs) 4. Male and Female connectors for HiFi Amp If you are able to help me that would be greatly appreciated! Thank You, MK |
10-02-2013, 11:05 PM | #3 |
Mr. Nice Says Hello
636
Rep 16,662
10-03-2013, 10:02 AM | #4 |
Mr. Nice Says Hello
636
Rep 16,662
Found the tweeters, anyone else willing to hlep me out lol
10-03-2013, 11:09 AM | #5 |
223
Rep 5,120
I don't see shy you need the male connectors for the speakers. If you are replacing your speakers you only need the female end that plugs into the stock harness, no use getting the end that plugs into the stock speakers if they are getting replaced anyways. Also the tweeters are connected to the mids with a passive crossover. That means there is only 1 pair of speaker wires coming out the door to your amp. You need a component set that comes with it's own passive crossover, and you don't need an additional connector for the tweeters. Unless you are wanting to run a seperate speaker wire from the tweeters to an active crossover but then I don't see why you'd need the stock connectors at all if you were gonna do that.
You can get the speaker and underseats connectors from the dealer search and you'll find part numbers. You can get technics harness for hifi. The only thing is it is meant for replacing the stock amp you cannot use the stock amp while using an aftermarket amp with that harness. |
10-03-2013, 11:31 AM | #6 | |
Mr. Nice Says Hello
636
Rep 16,662
10-03-2013, 11:34 AM | #7 |
223
Rep 5,120
10-03-2013, 11:36 AM | #8 |
Mr. Nice Says Hello
636
Rep 16,662
thanks, looked them over a bit, just wanted to see if I could just get a direct answer. Anyone know if it is possible to purchase the male and female connector of the HIFI amp?
10-03-2013, 02:04 PM | #9 |
Rep 25
Drives: 13 128i Msport
Don't quote me but I think someone in one of the stickies may have said it was proprietary to BMW so short of buying a used HIFI amp and wire harness I don't think you'll have much luck but maybe Techinc knows since he does the HIFI harness.
10-03-2013, 03:16 PM | #10 | |
2288
Rep 13,001
One last time (I posted these P/N before): Woofer housing: 61136901731 Woofer housing pins: 61138364835 Woofer socket: 61136984750 Woofer socket pins: 61138364838 Speaker housing: 61138373583 Speaker housing pins: 61130006664 Speaker housing socket: 61136925634 Speaker housing socket pins: 61130006663 MOST socket: 61138387214 Battery dist block housing: 61136925176 (single) Battery dist block housing: 61136925166 (double) Battery dist block housing pins: 61136920092 HiFi OEM amp female Connector: 8364862-03, 8364882, 8364884 |
