BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > CIC retrofit from CCC
      10-01-2013, 03:35 PM   #1
cn555ic
cn555ic's Avatar
441
Drives: 335i
I just retrofitted a CIC head unit into my 2007 E93 that came with the old outdated CCC head unit. Its so much nicer and the navigation is more advanced. The Center screen is also High definition compared to the older screen. Its much easier to navigate around also. I have been waiting to do this retrofit for awhile but the options out there were too costly, so I went ahead and bought bits and pieces from ebay and put the kit together myself to spend the least amount of money for this retrofit..
CIC Head unit $550 (Ebay)
CID HD screen $227 (Ebay)
iDrive controller and center console trim $105 (Ebay)
CID CAN/power connector to retrofit harnass to fit screen(61136954526) - $2.88 (dealer part)
CIC cable, connects to CID for video signal (61119185171) - $38.50 (dealer part)
USB Port (61319167196, superseded by 84109237656 ) - $26.50 (dealer part)
USB Port cable "cable for USB to glovebox" (61129196805) - $25.90 (dealer part)
CIC navigation voice emulator (Ebay) 78.76
Total 1028.64
I did the coding for the retrofit myself!
You need to change the VO (vehicle order) in order for NCS to see the retrofit CIC module. To do this you need to change the production date of the car..
-Mine was #0307 changed to #0909
-Add $6VA also to VO
-Then you Fa-write the VO to CAS and FRM module...
-Default code the CIC module which should show up in NCS after changing the production date.
THen everything should be up and running with the new CIC.
I then used NCSexpert to code in:
-DVD in motion
-Legal disclaimer disabled on startup
-Fuel stop stations
      10-01-2013, 04:12 PM   #2
madbim
madbim's Avatar
32
Drives: 08' E90 335xi
nice work! I'd like to do this someday!
      10-02-2013, 11:54 AM   #3
moreno1
moreno1's Avatar
73
Drives: BMW 335i E93
Nice work bro! Once you add the combox you will experience e a new world of options
2009 335i E93 /// BSM /// Sport /// Premium /// /// 19" M pack 225 wheels /// M6 wheels winter set /// 35% Tint /// Gloss Black Grills /// PE Exhaust /// Lux H8 V3 /// Interior LEDs /// JB4-DCI /// Combox & CIC Retrofit /// M3 side skirts /// M3 front bumper ///
      10-02-2013, 05:58 PM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
That's my next retrofit if I do anymore to
My car.
      10-02-2013, 09:17 PM   #5
paprmkr
BMW Enthusiast
paprmkr's Avatar
119
Drives: 2024 i5 M60 w/M-Performance ki
one day i will do it. also
      10-03-2013, 12:46 AM   #6
jpirelli
Power is nothing without control
jpirelli's Avatar
33
Drives: E90 + E92
Good job. How do you generate FSC?
      10-04-2013, 05:55 AM   #7
X.X.I.V
X.X.I.V's Avatar
77
Drives: 16 F80
+1
      10-04-2013, 07:19 AM   #8
cn555ic
cn555ic's Avatar
441
Drives: 335i
Originally Posted by X.X.I.V View Post
+1
YOu have to either buy the FSC code from the dealer, or people who sell FSC navigation map update codes, or you have the software to generate it which is not cheap.
I am very pleased with the outcome of my car at this point...Looks and feels like a new car from the interior
      10-04-2013, 12:50 PM   #9
makkan00
makkan00's Avatar
886
Drives: F83 and F36
+1
Glad to hear that.
Just imagine I went from standard radio to CIC and combox retrofit.
It is the best retrofit I have done so far.
Re: FSC code, if somebody wants it at reasonable price and has bmw coding software, then give me a shout.
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      10-04-2013, 01:02 PM   #10
Red_Bean_Bun
62
Drives: E92
Did you had the seller code the CIC components based on your vin before delivery ?
Or you did that yourself ? Did you update all the firmware ?
      10-04-2013, 05:41 PM   #11
cn555ic
cn555ic's Avatar
441
Drives: 335i
Originally Posted by makkan00 View Post
Glad to hear that.
Since you have done the combox can you give some insight on what is entailed as that seems to be the progression of my next retrofit. Also how did you get BMW apps working? Did you return to V41? My unit already had v41 from original software so I got lucky in that respect but when it came to updating navi maps it was torture via DVD disk! Lol
      10-05-2013, 12:32 PM   #12
makkan00
makkan00's Avatar
886
Drives: F83 and F36
combox replacing your mulf or tcu (whatever yo have).
combox 26 pin connector
Switching the wires from the mulf / tcu connector to combox connector
Cables for 6FL / 6NR (depending on the configuration)
Coding
      10-05-2013, 02:20 PM   #13
cn555ic
cn555ic's Avatar
441
Drives: 335i
I would save all the headaches and just get bimmeretrofit combox pnp harnass. What I need to know is people having SOS errors because they had BMW assist before. I still haven't heard anyone have any concrete info on how to get rid of this SOS error. Would you know? Or your car didn't have BMW assist to begin with
      10-05-2013, 02:27 PM   #14
xelion
Drives: 320d
If your car has factory BMW Assist then you just need remove 612 from VO and recode CAS, NFRM, CIC and KOMBI, it is necessary if you want to have INTERNET tethering through your Smartphone.
      10-05-2013, 02:50 PM   #15
joro2077
25
Drives: 335i E93
Good job. Congrats and enjoy!
      10-05-2013, 04:40 PM   #16
cn555ic
cn555ic's Avatar
441
Drives: 335i
So you finally got rid of your SOS by doing this? I was looking at your post asking for some help from Bimmeretrofit and they didnt respond to you. So this is the solution...Thanks man..
I just tested all functionality of the CIC and its soooo much better than the old CCC. I am in love with my car again!
      10-05-2013, 05:05 PM   #17
makkan00
makkan00's Avatar
886
Drives: F83 and F36
PNP is a good idea.
About SOS error, you only get it if you have TCU box.
If you have mulf/ high mulf, then no issues.
If you get stuck as SOS error, just give me a shout and I'll pm you the solution.
Done it on a car and its easy to deal.
      10-05-2013, 05:59 PM   #18
cn555ic
cn555ic's Avatar
441
Drives: 335i
I have a TCU for sure and I will definitely have SOS error. If you can please just pm me the solution. Thanks
      10-05-2013, 07:17 PM   #19
cyrano
Poland
16
Drives: E61 530XD chipped
Steve have you tried to add +TELD to vo ?
      10-05-2013, 07:52 PM   #20
j23a45m
j23a45m's Avatar
44
Drives: 2012 E70 X5
great work
2011 BSM 335i E90 MTECH 6MT • JB4 stage 2 iso 5.3 FF wire• BMS Intake • Vishnu DP • Cyba Scoops • LUX V4 • 6000K Headlight/Fog light Philips Ultinon • Euro headlight switch • ACS roof wing • 35% tint • Performance Grilles • Misc coding • Cobb charge pipe • ///M3 fenders • 335is pedals • BC Coilovers • Vrsf 7" IC • ///M3 mirrors •
      10-05-2013, 11:24 PM   #21
cn555ic
cn555ic's Avatar
441
Drives: 335i
I am just gathering info when I do the retrofit..I llike to be prepared for everything before I even start the retrofit...I also modified and fitted the CCC screen housing which had a protective plastic shield over the screen to my new CIC screen. I didnt like how it was just exposed and felt it looked much better with that plastic lens. I dont know why BMW would take that out but one reason would be cost savings just like the hood insulation and the flashlight in the glove compartment which BMW eliminated entirely...
SA39451.50
      10-06-2013, 01:42 AM   #22
xelion
Drives: 320d
I removed 612 from my VO and SOS error gone. That's the solution, really easy. I even didn't tru +teld, however my car is from march 2010 built date, and I just replaced TCU with Combox telematik. 5 minutes to switch a pins to new connector and another minute for coding.
Combox is really great thing, but I didn't add BMW apps because I have xperia Z smartphone and not the iPhone 4 and 4s, it is not cool that only these two mobiles can work with BMW Apps.
