HELP! VANOS CODE N55! What do I do?!
09-26-2013, 12:59 AM | #1 |
Rep 32
Hi,
So I drive a 2011 335i N55 and yesterday I was driving home and on the way i was trying to pass a car, hit the gas and as soon as i started to pick up, a malfunction light came on and immediately went into LIMP mode. I went to the shop today to see what codes it was and i got a code: P13C0. Cleared the code, and restarted the engine, within seconds the warning malfunction screen popped up again with another code. This time the code was P052B. I went ahead and looked up what the codes mean off the internet and this is what i came up with. P13C0 - VANOS intake: Closed loop control fault, camshaft sticks P052B - VANOS, intake side, cold-start: No closed-loop control possible What exactly does this mean? and what would i have to do to fix this? I already tried pulling the VANOS solenoid to clean it and no luck. In fact, it actually sounds even worse when running. I dont know what i should do at this point. Ive tried searching over the internet but no luck! Any pointers and help would be greatly appreciated! Thanks! Andrew UPDATE!!! I had replaced the VANOS intake solenoid with an brand new oem one and Still has not fixed the problem. Here is a video of what it is doing! (its a loud ticking sound!)
2002 E46 M3 / 2010 E82 128i Msport / 2015 Suzuki GSXR600 Last edited by WynterFreshEVO; 10-03-2013 at 01:52 AM.. |
09-26-2013, 06:23 AM | #2 |
441
Rep 18,331
Your vanos solenoids either need to be cleaned or changed out...Do a search on how to change it out or since you should still have warranty just bring it into dealership and they should fix it..
09-26-2013, 01:38 PM | #3 |
Rep 32
Ive taken them out already to clean them, and no luck. Light came back on within seconds of starting the car. Worse part is, my warranty expired 5k miles ago
2002 E46 M3 / 2010 E82 128i Msport / 2015 Suzuki GSXR600 |
09-26-2013, 01:52 PM | #4 |
964
Rep 3,854
Drives: 330i, 135i
You have no choice but to buy a new set. Easy install.
09-26-2013, 04:42 PM | #6 |
Rep 32
so at this point, is it safe to assume its my VANOS solenoid that went out? or is it my crankshaft sensor? or cam sensor? Just wondering if i should order the solenoid
09-26-2013, 04:52 PM | #7 |
964
Rep 3,854
Drives: 330i, 135i
I would start by replacing the solenoids since is what the errors you are getting. Most likely s all you have to replace at this time. Keep us posted.
09-26-2013, 05:18 PM | #8 |
Rep 32
I went ahead and ordered an intake vanos solenoid for $95 shipped. Cost $205 new from the dealer. Ill keep posted in the next couple days to see if it fixed the problem or not.
10-03-2013, 01:37 AM | #9 |
Rep 32
Turns out it did NOT FIX THE ISSUE! Now it has a horrible loud ticking sound.
12-15-2013, 11:23 AM | #10 |
44
Rep 696
Drives: 2012 E70 X5
sorry to bring up a old thread.
Did you finally figure out what it all was?
2011 BSM 335i E90 MTECH 6MT JB4 stage 2 iso 5.3 FF wire BMS Intake Vishnu DP Cyba Scoops LUX V4 6000K Headlight/Fog light Philips Ultinon Euro headlight switch ACS roof wing 35% tint Performance Grilles Misc coding Cobb charge pipe ///M3 fenders 335is pedals BC Coilovers Vrsf 7" IC ///M3 mirrors
12-24-2013, 09:01 PM | #11 |
Rep 32
nope, no one was able to figure it out. engine needs to be opened up to find out
12-25-2013, 06:44 PM | #12 | |
44
Rep 696
Drives: 2012 E70 X5
my dealer is doing it this week on my car
01-03-2014, 09:16 PM | #13 |
Rep 32
glad you figured it out! unfortunately, its too late for me, my engine blew already
01-04-2014, 03:02 AM | #14 |
44
Rep 696
Drives: 2012 E70 X5
ouch sorry to hear that.
07-21-2014, 07:30 AM | #15 |
drive to survive
87
Rep 443
I am a lil confuse you bought new vanos and it still didn't fix it. But the other guy said he replaced his and that fixed it. So what was causing the code and nose for you?
07-21-2014, 11:32 AM | #16 |
687
Rep 2,770
First, this thread is pretty darn old. Second, he said he replaced his VANOS solenoids at first. These control the VANOS motors themselves. This issue sounds like he had the (now known) VANOS bolts issue happen to him.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
07-21-2014, 02:56 PM | #17 |
drive to survive
87
Rep 443
I know it is an old thread. What's your point exactly??
07-21-2014, 03:11 PM | #18 |
687
Rep 2,770
That there have been developments since then. Also, this thread is in the Coding section where it is not likely to get a lot of input as this is not coding related.
You can check out the N55 section for more details on the VANOS recall issue I was referring to.
10-10-2023, 09:34 AM | #19 |
Rep 15
Maybe helpful
I know this is an old thread, but wanted to share just in case someone else is chasing this issue. I cleaned the Vanos solenoids (see various youtube videos for this) and changed the oil. Issue is finally gone. Just wanted to throw it out there as sometimes the simple stuff is overlooked. Quite frankly, changing oil may have fixed it on its own. Cheers.
