Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Radio Help
      09-23-2013, 08:21 AM   #1
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
Radio Help
Hey guys...I took out my aftermarket radio and installed my OEM radio but it doesn't turn on...can anyone advise...could it be a fuse?
///Mods: ER CP, Helix FMIC, Dinan FFE, BMS N55 Intake, VRSF Catless DP, proTUNED...///
      09-23-2013, 11:03 AM   #2
ctuna
1911
Drives: 325xi 06 wagon MT
Did you install the Aftermarket Radio?
Or did you buy the car with the aftermarket radio already installed.
Any programming changes once it was installed?
Get out the voltmeter.
Why are you putting the original back in?
      09-23-2013, 11:51 AM   #3
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
Thanks for the response...
I had an audio shop install the aftermarket radio...they cut the speaker wires in the process, lost my pdc and chimes...i reattached everything as if going back to stock to basically do it myself with the correct harnesses...but when I attach the OEM HU it doesn't turn on...
      09-23-2013, 12:46 PM   #4
ctuna
1911
If you have a pinout of the head unit harness.
Better recheck your wiring.
And start measuring for 12 volt power and standby.
Also check the fuses.
This may help.
http://www.e90post.com/forums/showth...ight=head+unit
http://www.e90post.com/forums/showthread.php?t=319976
      09-23-2013, 01:02 PM   #5
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
This may help.
Thanks...i'll try again later when I get home...
      09-23-2013, 11:24 PM   #6
Viktimize
10
Drives: 2007 335i, 2002 325i
You need to tap both the switched and constant power sources from the fuse panel. You won't get switched power at all from the harness, and the constant power isn't constant, it kicks out after 20 minutes of shutdown.
Amazingly very few people here seem to know about the switched 12v issue. I had the same problem when I installed my HU and nobody was able to help me either.
      09-24-2013, 11:41 AM   #7
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
This may help.
It was a blown fuse...the old HU is working fine now...now its time to start the wiring of the new one...
      09-24-2013, 11:44 AM   #8
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
can you provide some more insight on how to tap into both switched and constant...this is the first time im doing anything like this so any help is appreciated...thanks
      09-24-2013, 12:16 PM   #9
ctuna
1911
Use a harness don't hack the car.
There are a lot of hack installers out there that will ruin your car.
      09-24-2013, 12:20 PM   #10
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
thats what happened here...thats y im going to end up doing it myself...got both harnesses jus have to figure our the wiring and power...
