Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Audio for iPhone 5 and 5s?
      09-20-2013, 07:56 AM   #1
AustinJerry
47
Drives: F82 M4 Black/SB w/6MT
I have been enjoying using my iPhone4 in my coupe for several years. I have a Proclips center console mount with a cable that has both a 3.5mm stereo plug that connects to the AUX IN connection, and a USB plug that connects to the lighter power outlet inside the console with a USB/lighter adapter. I use the iPhone as the primary source of music while driving (Pandora, MOG).
I want to upgrade to the iPhone 5c, but my understanding is that the Lightning connector outputs digital audio, not analog audio like the old connector.
For you iPhone 5 users, how are you getting audio to play through the BMW sound system? I believe Apple sells a Lightning to 30-pin converter, does this convert the audio to analog as well? How about holders that work with the Lightning-to-30-pin converter? Thanks for any advice!
      09-20-2013, 08:20 AM   #2
MrPig
MrPig's Avatar
14
Drives: '11 STI, '90 325iS
1990 BMW 325is  [10.00]
I use bluetooth streaming, but it also worked through lightning -> USB port found in my arm rest. My e90 is an '11 though and from my understanding it's a different setup for earlier model years.
      09-20-2013, 10:51 AM   #3
CaliBMW86
Drives: BMW 335i; Ducati S4RS
I had a huge issue with impedance with my car, so I came up with a different solution which may also help you.
Use a usb drive (not all work for some reason but below is the setup i bought and it works perfectly). The reason this setup is the best way to go is that you can use your nav or radio display to search your music, instead of looking down at your phone to change songs. The best part of it all no cables.
http://www.amazon.com/SanDisk-Mobile...ndisk+micro+sd
http://www.amazon.com/Sandisk-Mobile...icro+sd+reader
      09-20-2013, 10:55 AM   #4
CoralRed335XI
98
Drives: 2008 E92 335XI Coupe
2008 BMW 335XI  [3.66]
I use the 30-pin to lightning adapter with the OEM ipod cable. Works fine and retains all previous control functionality. BTW try out itunes radio... I like it better than pandora or slacker.
2008 E92 335XI, Space Gray on Coral/Fox Red Hybrid M3 seats, Premium, Cold Weather, Comfort Access, iPod.
Mods: Fox Red M3 seats up front, KW V1, ER CP + TIAL BOV.
      09-20-2013, 11:47 AM   #5
AustinJerry
47
I don't see how this would allow access to streaming Internet radio. BTW, what do you mean "impedance issue"?
      09-20-2013, 11:48 AM   #6
AustinJerry
47
I was hoping this would work. Thanks for confirming. Cable ordered.
      09-20-2013, 11:50 AM   #7
CoralRed335XI
98
Glad to help
      09-20-2013, 12:31 PM   #8
iturbo_bmw
iturbo_bmw's Avatar
84
Drives: 335i, 530i
+1 just get the adapter. it makes the cord a little longer too if you need to use ur phone
      09-20-2013, 01:39 PM   #9
CaliBMW86
Impedance issue is where static noise comes from the speakers.
I forgot about the streaming music part, yea that would not help for that.
Another reason why I switched to the mirco sd is it will give you surround sound audio, a 3.5mm audio jack only gives you 2.1 instead of the 8.1 (8 speakers 1 sub) with surround sound.
      09-23-2013, 10:26 AM   #10
everlast
Malt'm'n'Salt'm
14
Drives: 2008 328xiT
Wot?
      09-23-2013, 11:09 AM   #11
CaliBMW86
Originally Posted by everlast View Post
Wot?
You trying to ask an actual question? Not sure how to reply to: wot?
      09-23-2013, 12:17 PM   #12
everlast
Malt'm'n'Salt'm
14
Drives: 2008 328xiT
More a reflection of disbelief of noise caused by impedance issues and that you have true multichannel audio being played in 8.1 from a micro-sd card. *shrugs*
      09-25-2013, 09:56 PM   #13
EMITTR
EMITTR's Avatar
95
Drives: 11 335is Coupe BSM
Spoke to BMW about this yesterday. The iPhone 5 is still not supported. The only way if you want to use your iPhone 5 is to use the analog aux. Buy a dual connector and connect it inside your arm rest - if your aux input is there. Outputs to your speaker system by you cannot control it through the car's iDrive.
My OP ED to BMW if they are for some infinitesimal reason, monitoring this forum - "BMW bloody software engineers....you are too slooooooooooooooooooooooooow! If you are going to be one of the first to integrate mobile tech in to your product then at least get off your lazy arses and keep your produce up to date with the tech! - you charge enough for your product - keep it up to date!"
Ok...my rant is over.
'11 BSM DCT 7 Spd. 335is | RPi | aFe Magnum Flow Direct Fit | Interad DTM 10 Forged | Smoked Reflectors | Huper Optik Tint | Arkym Rear Diffuser | Cyba CF Quad Tips | iND CF CRT Rear Spoiler | COBB Protune | Turbosmart BPV | AutoCarbon CF Grills | Silver CF e-Brake | BMW CF Mirror Shrouds | M Perf. Steering Wheel v2 | KW DDC Coilovers w/WLAN | Interior Xenon LEDs | Custom 335is Accents | F/R Fenders Rolled & Pulled | New Pipes Baffle Delete
      10-03-2013, 11:58 PM   #14
AustinJerry
47
Regarding the static noise, did you adjust the AUX Input level? If it is too high, it over-drives the BMW electronics, which results in distortion. An input level of 2 or 3 is appropriate.
      10-04-2013, 11:00 AM   #15
CaliBMW86
Even at level 1 their is noise. The issue deals with the fact that most aux inputs in cars do not have enough power supplied to power the signal. My current Samsung Galaxy S4 has lower RMS current, and due to the limited power of the aux input it picks it up as static. I added an amplifier in between the phone and aux input in the car, and the problem goes away. A lot of people have this issue. I had the same problem when I used my iPhone. This issue was not a problem in my previous car (a Camry with JBL sound system which had a lot more power then the Logic 7 audio system I have now).
My solution was to use a micro sd card with a card reader for my music, that way it displays in my nav screen, and you get dolby digital versus 2.1 from 3.5mm audio cable.
      10-05-2013, 07:47 AM   #16
jaquarda
Drives: 2020 G20 M340i, 2013 E92 M3
I drive a 2011 335d with Connected Drive. I plug in my iPhone 5 to the USB port in the center arm rest using the lightning/usb cable that came with the phone. It works perfectly just like it did when I had an iPhone 4.
      10-18-2013, 12:03 PM   #17
Grimes_MG
Drives: 2009 E93
I can confirm that the lightening-to-30pin adapter sold by Apple for $39.99 allows audio and the iPOD information (album, artist, tract, etc.) to be transmitted from my iPhone 5S with iOS 7.0.2 through the Y-cable to my iDrive for my 2006 E93. Mine is pre-Advanced Audio Distribution Profile (A2DP).
      10-18-2013, 12:40 PM   #18
techy1
techy1's Avatar
Trinidad_and_tobago
21
Drives: 2008 328i
+1 on this as well. but What i found its that the bmw y cable and the 30 pin to lighting must be oem in order to work correctly I tried using a china adapter and the car just wouldn't read it.
[ 2008 328i, 20% Tints, ST Coils, 19's Miro 111, PSS, LED Angel Eyes, Lumens HID Fog lights, Blacklines, matte black Grills ]
