Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > Car Audio FS: 1 JL Audio e1200 Amp + 1 JL Audio 10w0 w/ Sealed RoxBox
      12-07-2005, 11:15 PM   #1
XI JR IX
Drives: 2006 325xi
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
Hey Guys,
This was part of my old system that I only had for a few months and then decided to upgrade. Everything is pretty much brand new, no scratches on the amp or sub. I've got the full boxes for both the amp and sub. If you are interested reply or pm me. I don't have pictures yet but I can get them this weekend if you want. I've also got a Alpine CDA9811 if anyone wants to make me an offer on that.
-- $500 CDN -- (Or Best Offer)
| JL Audio e1200 Class A/B Monoblock Full-Range Amplifier |
General Specifications:
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V)
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm / 50 Hz
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
http://mobile.jlaudio.com/products_amps.php?amp_id=257
| JL Audio 10w0 10" Subwoofer |
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Available Configurations: 4 ohm or 8 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 0.50-0.90 cu.ft. (14.0-25.5 liters)
Ported Enclosure Range: 0.90-1.50 cu.ft. (25.5-42.5 liters)
VRCĂ?Â? Technology: YES
      12-14-2005, 12:26 AM   #2
XI JR IX
Drives: 2006 325xi
Here are the pics..
The Dimensions of the Box are:
Width - 25 3/4 inches
Height - 13.2 inches
Depth - 12 inches (1ft)
      12-15-2005, 07:39 PM   #3
Big Mike
Drives: 325i Monaco Blue
Re: Amp Sub
Hey, I have an 06 325i and have some terrbile crakcing from the front three speakers. Its been ion twice and gotten two new amps but after the last time the service manager explained that theyre is nothing more they can do and he was sorry.
Do you think this amp would help in my car? Would you sell it without the sub. Would the sub be too loud in this car? How much do you think it would be to hook up?
Thanks
Mike
      12-18-2005, 11:45 PM   #4
XI JR IX
Drives: 2006 325xi
Thanks
Mike
This amp would not help your situation. This is a mono amp, meaning that you would only use it to provide the best power for a subwoofer. You would not run door speakers off this amp.
      12-22-2005, 10:30 AM   #5
Arby 330
16
Drives: jet black 330
so this is a 1200 wat amp..... how much for just the amp
330i- Jet Black/black leather/aluminum trim/sports/premium/nav-IDrive ....every single option available (steptronic )
5% suntek- all the way around (15% strip on front winshield)
Search this Thread:
Advanced Search
