E90 lci rear lights HELP!
09-16-2013, 04:23 PM | #1 |
- Speed Matters -
Rep 228
Hey wasup everyone
I have just had a pre lci to lci rear conversion done, must say it looks amazing.. However just a few questions on some issues and just wondered if its just down to needing coding, Firstly, the right indicator blinker is dimmer than the left. And when indicating left or right it blinks really fast. Secondly, i have noticed that the inner lights are lit up alot brighter red compared to the outer red lights almost as if the rear fog lights are on.. Anyone experience any issues like this, would appreciate feedback! Thanks in advance |
09-17-2013, 06:42 AM | #2 |
Rep 50
First of all, you need to rearrange the wire order for inner lights...
After this gets done, the lights will light up properly... Last piece of job is to code-out some bulb check... I used this on my 2006 build e90 with FRM1: KALTUEBERWACHUNG_BLK_H_L nicht_aktiv KALTUEBERWACHUNG_BLK_H_R nicht_aktiv WARMUEBERWACHUNG_BLK_H_L nicht_aktiv WARMUEBERWACHUNG_BLK_H_R nicht_aktiv The lines above can be find in FRM(NFRM) section of your CAS module in NCS Expert Tool ... Good luck! |
09-17-2013, 06:46 AM | #3 | |
- Speed Matters -
Rep 228
09-17-2013, 08:29 AM | #4 |
Rep 50
Ok, you're right. You need to switch drivers & passenger side... So if we go from begining, just use drivers side wiring order from photo on your passenger side, and vice versa.... It should work
Let me know if you've managed to get it working Here you go: |
09-17-2013, 08:32 AM | #5 | |
- Speed Matters -
Rep 228
