TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > TOOL32 FRM Error Code list
      09-05-2013, 06:17 PM   #1
cn555ic
cn555ic's Avatar
441
Drives: 335i
Hope this can help to decipher the codes being thrown by the FRM module so you can find a fix for it or understand what the error that has been stored in the lighting module..
Code:
CODE	ERROR MESSAGE
0x9CA8	Internal error
0x9CA9	Clamb 30A connection faulty
0x9CAA	Clamb 30B connection faulty
0x9CAB	a clamb 15 missing
0x9CAC	Brake light switch defect
0x9CAD	Energy saving mode active
0x9CAE	colourswitch defective
0x9CAF	stage light switch 1 defect
0x9CB0	stage light switch 2 defect
0x9CB1	Dimmer potentiometer defective
0x9CB2	LWR potentiometer defective
0x9CB3	Front level sensor defect
0x9CB4	Rear level sensor defect
0x9CB5	Battery deep discharched
0x9CB6	LWR coil break
0x9CB7	LWR driver error
0x9CB8	prevention battery deep discharge: switch off parking light
0x9CB9	prevention battery deep discharge: switch off parking light
0x9CBA	Communication with LIN control defective
0x9CBB	short-circuit
0x9CBC	short circuit door contacts front
0x9CBD	short circuit door contacts rear
0x9CBE	Control error
0x9CBF	Communication with StepperEngineBox left disturbed
0x9CC0	Communication with StepperEngineBox rigth disturbed
0x9CC1	Attention: Electronic at the left headlights (SMC) reports an Error
0x9CC2	Attention: Electronic at the rigth headlights (SMC) reports an Error
0x9CC3	Communication with mirror driver side defective
0x9CC4	Communication with mirror Passenger side defective
0x9CC5	mirrorheating driver side defect
0x9CC6	mirrorheating Passenger side defect
0x9CC7	Hallsensor Power window driver door defect
0x9CC8	Hallsensor Power window passenger door defect
0x9CC9	time window Power window driver door defective
0x9CCA	time window Power window passenger door defective
0x9CCB	Relay Power window driver door defect
0x9CCC	Relay Power window passenger door defect
0x9CCD	Drive Mirror driver side defect
0x9CCE	Drive Mirror Passenger side defect
0x9CCF	Drive flap in Mirror driver side defect
0x9CD0	Drive flap in Mirror Passenger side defect
0x9CD1	Comparison vehicle identification number ALC with SMC at the left is different
0x9CD2	Comparison vehicle identification number ALC with SMC at the rigth is different
0x9CD3	inconsistency: Software version and coding index
0xA8A8	Left high beam defective
0xA8A9	Right high beam defective
0xA8AA	Dipped headlight left defective
0xA8AB	Dipped headlight right defective
0xA8AC	Corner light left defective
0xA8AD	Corner light right defective
0xA8AE	Fog light left defective
0xA8AF	Fog light right defective
0xA8B0	Indicator front left defective
0xA8B1	Indicator front right defective
0xA8B2	Left rear indicator defective
0xA8B3	Right rear indicator defective
0xA8B4	E70: Corner light front left, R56: Colour-Switch orange defective
0xA8B5	E70: Corner light  front right, R56: Colour-Switch blue defective
0xA8B6	Left brake light defective
0xA8B7	Right brake light defective
0xA8B8	Center brake light defective
0xA8B9	Tail light left 1 defect
0xA8BA	Tail light right 1 defect
0xA8BB	E70: Tail light left 2, R56: Corner light front left, rear right defect
0xA8BC	E70: Tail light right 2, R56: Corner light front right, rear left defect
0xA8BD	Registration plate lift defective
0xA8BE	Interior light defective
0xA8BF	Left rear fog light defective
0xA8C0	Rear fog light right
0xA8C1	Left back-up light defective
0xA8C2	Right back-up light defective
0xA8C3	Break force display left defective
0xA8C4	Break force display right defective
0xA8C5	Day driving light left defective
0xA8C6	Day driving light right defective
0xA8C7	Clamb 58g defective
0xE584	Bus wire error K-CAN
0xE587	Bus coummunication error K-CAN
0xE594	Telegramm steering angle timeout
0xE595	Status AHM telegram timeout
0xE596	Telegram high beam assistant Timeout
0xE597	Telegram Status DSC Timeout
0xE598	Telegram Status driving ligth Timeout
0xE599	Telegramm speed timeout
0xE59A	Telegramm yawing rate timeout
0xE59B	Telegramm clamb status timeout
0xE59C	Telegram PT-CAN steering angle Timeout
0xFFFF	Unknown error location
