09-03-2013, 03:47 PM | #1 |
1417
Rep 2,650
APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly. APEX 75mm and 90mm Stud Kits with silver or black lug nuts Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles. APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Available Sizes and Pricing:
Available Lug Nut Finishes
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench) Apex Extended Lug Bolts Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating. BMW extended lug bolts sold individually Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts. Lug Bolt Specifications:
Available Lug Bolt Finishes Silver Black - +$0.50 RAD Extended Wheel Locks
Ordering and Contact
01-29-2014, 05:57 PM | #2 |
1417
Rep 2,650
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
Please call, email, or pm us with any questions you may have.
04-10-2014, 11:39 AM | #4 |
3467
Rep 6,683
You can surely just purchase the 75mm studs by themselves at $4.99 a piece, though they are not yet available on our website. Please give us a call at 888.499.9135, or send us a PM/ email if you would like to place an order for individual studs.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
04-22-2014, 07:37 PM | #5 |
1417
Rep 2,650
APEX is now offering RAD Extended Wheel Locks!
Please contact us if you have any questions!
05-12-2014, 07:30 PM | #6 |
3467
Rep 6,683
Swap wheels a lot? Make it easier by doing a stud conversion.
75mm stud conversion kit with black lug nuts We've got plenty of kits in stock for the 75mm stud lengths, so feel free to give us a call if you need to order a set.
05-16-2014, 06:14 PM | #7 |
3467
Rep 6,683
90mm studs are back in stock, feel free to order them through our site here.
06-16-2014, 04:29 PM | #8 |
1417
Rep 2,650
APEX black extended 75mm studs paired with some custom aggressive Red ARC-8's. Contact us with any questions, we would be happy to walk you through the APEX hardware available for your BMW!
06-24-2014, 05:42 PM | #9 |
1417
Rep 2,650
Get your extended stud kit today! Available with silver or black lug nuts.
07-11-2014, 05:42 PM | #10 |
1417
Rep 2,650
Our BMW lug bolts come in standard lengths for cars without spacers as well as extended lengths for cars running up to a 20mm spacer. They're available in all sizes in black or silver:
Give us a call to order your set of lug bolts today! |
08-18-2014, 05:18 PM | #12 |
1417
Rep 2,650
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out! |
10-03-2014, 06:00 PM | #13 |
1417
Rep 2,650
Apex Stud Kits are in stock and ready to ship!
