      09-02-2013, 08:23 PM   #1
AlexGT
AlexGT's Avatar
Guatemala
417
Drives: G05 X5 MSport
130i sucking gas like a sponge, please help!
Could someone suggest any reasons why my 2007 130i fuel consumption is so high? I'm not kidding, I'm getting 20kms (12.4miles) per gallon!😩
The car has no noticeable problems, no hesitation, not lazy, no acceleration issues, no weird sounds
What could it be? Thanks for helping me out!
Proud BMW owner
E87 130i — E90 LCI 320d — F22 M235i — F15 X5 30d
F30 LCI 320i MSport — G05 X5 30d MSport
      09-02-2013, 11:59 PM   #2
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
292
Drives: 911, 130is, E39 M5, E36 M3
Automatic transmission on your car?
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      09-03-2013, 03:00 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10511
Drives: N54 e82
is that US gallon or Imperial gallon?
Auto or Manual?
City driving or highway?
I would pull a sparkplug out and have a look. Also have you checked for any codes? Sometimes your engine will throw a code but not turn on an engine check light.
I would also look at your O2 sensors and the Lambda values with the engine running. That will tell you whats going on.
You could also have a simple vacuum leak and the engine will dump in more fuel to compensate for it. You could spray some NON-flamable brakekleener around the intake with the engine running to see where a vacuum leak is.
      09-03-2013, 08:54 AM   #4
AlexGT
AlexGT's Avatar
Guatemala
417
Thank you all for your responses. Mine is automatic transmission. It is basically city driving with medium to heavy traffic.
I will check the air sensor and also for error codes. Could this be also related to the fuel filter?
I will also try to do the leak check
Proud BMW owner
      09-03-2013, 08:58 AM   #5
TheSt|G
TheSt|G's Avatar
292
Looks like there is a good chance you need a software update. We had another member in the N52 engine section reporting the same problem and had it fixed via a DME update:
http://www.1addicts.com/forums/showthread.php?t=809599
the fix...
http://www.1addicts.com/forums/showp...9&postcount=66
      09-03-2013, 08:28 PM   #6
AlexGT
AlexGT's Avatar
Guatemala
417
http://www.1addicts.com/forums/showthread.php?t=809599" rel="ugc" target="_blank">http://<a href="http://www.1addicts....p?t=809599</a>" rel="ugc" target="_blank">http://<a href="http://<a href="http...809599</a></a>
Actually I did an ECU remap in January. I got the car enhanced from 265hp to 280hp. But before that change I already had this fuel consumption issue . I had tried Liqui Moly additives (different types), changing my way driving, changed the spark plugs to NGK iridium... I have a magnaflow catback and a K&amp;N filter (not an intake, just the filter).... Oh well...
I really appreciate your guidance bro and everybody else too. (y)
Proud BMW owner
      09-03-2013, 11:33 PM   #7
631twentyeighteye
631twentyeighteye's Avatar
198
Drives: 08 335i
The flash only writes over your current DME tune. You need BMW to update your car/transmission modules to fix the issue assuming its the same problem as the other person had. You're tuner can put another tune on after they update your DME as it will be erased after it comes back from the dealer, they are usually happy to help.
08 e93 335i MT
      09-04-2013, 01:43 AM   #8
Dackelone
European Editor
Dackelone's Avatar
Germany
10511
Drives: N54 e82
^^+1.
      09-04-2013, 06:57 PM   #9
AlexGT
AlexGT's Avatar
Guatemala
417
Thanks man! I will try and see if the BMW dealer does this and then the shop that re-programed my car re-does it hehe
Cheers to all!
Proud BMW owner
      09-04-2013, 09:47 PM   #10
TheSt|G
TheSt|G's Avatar
292
Cheers to all!
Here's hoping it sorts you out.
Search this Thread:
Advanced Search
1addicts
