Stock amp always warm/hot, even when off --Why?
08-31-2013, 09:59 PM | #1 |
Rep 48
I have an 06 330i that's pretty much loaded, including iDrive and what I think is called "Logic7" audio.
So anyway, it seems like the amp (in the trunk) is always on, even if I'm not using the audio system. You can feel that it warmed up after a few minutes of driving. In fact once it got hot enough to activate the fan inside the amp. Why is this necessary? Seems like it would drain the battery if you primarily make short trips. |
08-31-2013, 11:31 PM | #2 |
1911
Rep 13,104
If you have the doors open the car is still awake.
The car stays awake as long as the doors are not locked and you are near it with a keyfob . The only way to get it to go to sleep fairly quickly is to lock the doors. If you do this thec car should go to sleep in roughly 1 to 2 minutes. Having the trunk open also qualifys as a condition to keep the car awake. Read this http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja If you ever try to wash you car and you have a comfort access keyfob in your pocket the locks go nuts. And actually it does drain the battery the car will draw .5 amps when awake and about 20 ma when asleep. That's why they recommend a battery tender for low use or people that have short drives and low usage. |
09-01-2013, 06:02 AM | #3 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-01-2013, 07:25 AM | #4 |
Rep 48
I don't have Comfort Access, it's the only option I don't have.
And I'm not talking about when the car is awake, I'm talking about when I'm driving. If I'm not using the radio or handsfree, the amp should be off. A big amp like that isn't necessary to produce chimes. |
09-01-2013, 08:16 AM | #5 | |
300
Rep 3,969
09-01-2013, 09:07 AM | #6 |
Rep 48
Well I'm clueless about electronics, but if it only consumes 0.5 amps then I guess there's no issue. I just assumed that any accessory that gets that hot would consume a lot more.
I still don't see the need for chimes to go through every single speaker, lol. The system sucks compared to the Harmon Kardon in the E46 ZHP anyway. Doesn't seem as sharp and clear. Last edited by Bbox; 09-01-2013 at 11:29 AM.. |
09-01-2013, 10:58 AM | #7 |
1911
Rep 13,104
.5 amps is a lot from something that's not doing anything.
Basically waiting for Inputs and powered by a battery. Yeah it seems wildly inefficient from an Engineering standpoint to have it on when its not playing music. But you wouldn't want to stifle some Engineers creativity would you. I wonder if this kind of thinking only came from the Bammerizaion period. Funny I liked the E46 HK better than the Hi Fi but I haven't heard it was better than the L7. It was about the only system I got in a car I didn't want to change. Last edited by ctuna; 09-01-2013 at 11:05 AM.. |
09-01-2013, 11:51 AM | #9 | |
223
Rep 5,120
That fan doesn't use nearly enough power to drain your battery. Many of us here have upgraded the audio system and are using alot more power with no issues. |
09-01-2013, 12:00 PM | #10 |
Rep 48
I don't care about the little fan, I care about the amp itself. Getting hot to the touch with no sound? That's just retarded. I mean if you're only making a short trip of 2-3 minutes, how is the battery going to fully charge back up if all these accessories are constantly being powered? Some of us don't have a garage with a power outlet for a battery tender.
09-01-2013, 12:02 PM | #11 |
10
Rep 206
09-01-2013, 12:13 PM | #12 |
1911
Rep 13,104
I guess you could put it in a metal box.
I guess you could put it in a metal box .
That blocks radio waves. I sometimes do that to hide the key and go surfing. A Mentos box works pretty good but test it. Its useless getting emotional about this it is what it is. Yes there are many complaints about the battery getting low and going bad prematurely with this design. Opening or unlocking the car ,opening any of the doors or trunk wakes it up. I am not sure but coming near it with CA may also wake it up. If you lock the doors it goes to sleep in about a minute or two if you don't it may take up to a half hour. Last edited by ctuna; 09-01-2013 at 12:24 PM.. |
09-03-2013, 11:18 PM | #14 |
1911
Rep 13,104
Read these
