JL HD900/5 sub wiring?
08-31-2013, 02:59 PM | #1 |
10
Rep 375
With only 5 channels that means I need to either run the underseat subs in parallel or series. What is the better accepted way to run them, I haven't really looked at the stock sub specs yet? (Using Technic harness BTW)
08-31-2013, 03:17 PM | #2 |
1911
Rep 13,104
Underseats on seperate channels is standard.
Under seats on separate channels is standard.
That a great amp but the sub channel is intended for an actual trunk sub I think. You aren't probably going to find any stock sub specs for anything but 2 ohms for a hi fi. The don't list wattage I think unless its on the speaker physically. since you are putting that high wattage amp on I think you need to look at upgrading any speakers that you are running a channel to , especialy if you have a base of Hi Fi system . All Hi Fi speakers are 2 ohm . Last edited by ctuna; 08-31-2013 at 03:29 PM.. |
08-31-2013, 04:17 PM | #3 |
300
Rep 3,969
It doesn't matter from an acoustical standpoint. If you have Hifi, the woofers are 2ohm, so putting them in series will result in a 4 ohm load for the amp. In L7, woofers are 4 ohm, so parallel will result in 2 ohms. HD900/5 sub channel can drive 1.5-8 ohms, but output will be reduced at 8ohm, which may not be a bad thing considering you are driving OEM subs. Be very careful, this amp will smoke those woofers in a heartbeat!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-31-2013, 09:42 PM | #4 | |
10
Rep 375
08-31-2013, 11:38 PM | #5 |
1911
Rep 13,104
Here is a bunch of stereo info for the stock system
BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://www.e90post.com/forums/attach...1&d=1209780865 http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 |
09-01-2013, 08:27 AM | #6 |
255
Rep 2,547
I would run 2 channels for the door mids/tweets and 2 for the under seats. You can run the rears off the head unit directly. Then save that hd900 sub channel for a real sub.
