8" low profile Kicker SSMB 8 underseat woofer/mid range - £200 + del
08-27-2013, 06:07 PM | #1 |
38
Rep 405
8" Low profile Kicker SSMB 8 underseat woofer/mid range - £200 + delivery.
Shallow depth, will need custom spacer, best for mids (unlike earthquakes). My audio project is complete now so clearing up all parts as I need some space. See my other threads for other audio bits.
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI |
08-28-2013, 03:55 AM | #2 |
28
Rep 901
is this for 1 or a pair?
Pre LCI Monaco Blue e90, iDrive, 18" 220M reps, M3 Front Bumper, LCI headlights, Darklines, Eibach Pro Kit [Build Thread]
ICE: DLS R4s, Gladen HG-201BMW-3, Alpine PDX 4.100 |
08-28-2013, 06:42 AM | #3 |
38
Rep 405
Pair.
08-28-2013, 07:39 AM | #5 |
38
Rep 405
It is not straight drop-in but (neither is Earthquake SWS-8s) this will need a custom spacer. With spacer this is shallow enough to be installed in our cars and there aren't many after market choices available to us mainly because of shallow depth.
If you google you can find a thread with full detailed pictures (perhaps somewhere on this forum) showing what was needed to get SSMB installed.
08-28-2013, 08:05 AM | #6 |
28
Rep 901
Do you know how much delivery would be?
08-28-2013, 08:57 AM | #7 |
38
Rep 405
PM me with your address pls.
08-28-2013, 09:12 AM | #8 |
38
Rep 405
Generally it should be £8-10. This size speakers are generally heavy.
08-28-2013, 02:05 PM | #9 |
28
Rep 901
Pm sent
08-28-2013, 02:42 PM | #10 |
38
Rep 405
All pm replied.
08-31-2013, 01:02 AM | #12 |
38
Rep 405
Full specs are here
175 watt per speaker will be very very loud. Details: Tri-Tech™ cone (sandwiched foam, polypropylene, and woven carbon fiber) Santoprene™ rubber surround low profile stamped steel basket spring-loaded nickel-plated terminals accept heavy-gauge speaker wire free-air capability recommended power range 40-175 watts RMS maximum peak power 350 watts frequency response 30-500 Hz sensitivity 89 dB flush-mount depth 2-5/16" Recommended Q-Logic Box Type: none warranty: 1 year
08-31-2013, 01:04 AM | #13 |
38
Rep 405
Speakers in very good condition. See pic here.
Delivery is £9.60 fully insured. Got it imported from the US to install in my car but didn't have enough time to do it with custom spacers etc, I went easy jehnert route but this is much better mid-range driver with a punch. I am still not sure if this is compatible with E60 (one I drive) as E60 underseat enclosure are slightly different then E9x and seat rails go right on top of it. As this speaker is highly flat flushed kind of carbon fibre surface I was worried it may be restricted by seat rails. Didn't want to work too hard on it only to findout it doesn't work. I know for a fact it works for E9x chassis. One install thread here.
Previous X5 40d M Sports and 535d LCI Last edited by afsar; 08-31-2013 at 01:12 AM.. |
08-31-2013, 04:30 PM | #15 |
38
Rep 405
Which bmw amp have you got? Hi fi or Logic 7?
09-23-2013, 07:42 AM | #16 |
38
Rep 405
bump
09-23-2013, 10:42 AM | #18 |
38
Rep 405
AWBimmer, to be honest I have never heard them side by side to compared them due to sheer volume of modding required to fit these in my E60 but judgeding by the looks and build quality I am sure it will sound better then Jehnert. I felt Jehnert to be slightly weird sounding for mid-bass, if I play Jehnert xe200 underseats on its own it it sounds more like sound produced by something hitting long wide metal pipe which has a tinny end in the tune. It could be my car, my jehnert or something own, whatever I can't say it is normal.
I wish I had e90 to try these ones, or loads of spare time to make my own plastic spacer for this underseats.
Previous X5 40d M Sports and 535d LCI Last edited by afsar; 09-23-2013 at 10:49 AM.. |
